|  | Home > Technical (L322) > OBD Scanners/Readers Info |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014      |
 With the increasing complexity of cars it is nearly impossible to perform even a basic fault diagnostics without some way of querying the information stored in the car's ECU.
|  12th May 2009 10:34pm |
| RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597      | Can I ask which OBD you went for? Also, I notice you had data from your P38, have you tried it on your L322?
|  12th May 2009 10:59pm |
| ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936      | Dan are you only interested in reading the data rather than reading and resetting the DTC's | ||
|  13th May 2009 5:56am |
| ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936      | I'm very tempted to get the Bearmach one | ||
|  13th May 2009 8:08am |
 Steve, I went for one very similar to This . (eBay links stop working after a while, just search for "USB OBD") Yes I have used it on the L322, quite a few times when I was tracking down and resetting codes due to my leaky PCV system, like I said, I wouldnt be without it now.   | ||
|  13th May 2009 8:51am |
 Any one you buy should come with good instructions, generally they are fairly simple. DigiMoto I find has the best user interface. Sometimes you have to assign the com port to the USB manually (usually if you plug it into a different port than the one you installed it on) but this isn’t as daunting as it sounds!   | ||
|  13th May 2009 9:07am |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383    | Great post Dan, thanks for clearing the mist! Discovery 4 HSE
|  13th May 2009 9:13am |
 Ken, As any OBD Reader's main purpose is to read and reset the Error Codes or Diagnostics Trouble Codes that is my main reason for having one, but as I also wanted to be able to read extended data that's why I bought and would recommend the USB one. Dan   | ||
|  13th May 2009 9:16am |
|  13th May 2009 9:23am |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014      | Which Bearmach one would that be? U got a link?  | ||
|  13th May 2009 9:38am |
| RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597      | Cheers Dan,
|  13th May 2009 5:23pm |
| Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262      | The price has dropped then for the USB ones. Some of the ELM chip based USB units were upwards of £80 only last year and the software (usually shareware) was partially in Hungarian.
|  14th May 2009 8:13am |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014      | Lets face it, they've always been made in China for 50p its just we've been paying a disgusting markup!  I think I paid about £25 for my ELM327? from China.  | ||
|  14th May 2009 8:50am |
| EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181    | Hi,
|  14th May 2009 4:06pm |
| Posting Rules
 its good having an unbiased view on this subject if you have read the D3 thread you know what I mean
