![]() | Home > Technical (L322) > limp mode |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
hhmmm, not sure as your faults cover a variety of sins .....
v3mmtrangerover Member Since: 29 Jan 2020 Location: sunderland Posts: 30 ![]() ![]() ![]() |
everything that has been suggested on the forum so far I have done so passed it to the garage and even he hasn't pined it down yet god knows how much its going to be billed for when/if he can even fix it sick isn't the word |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 778 ![]() ![]() |
What fault codes are showing? |
P0913-Fuel rail pressure to high input
They're not the codes I've had to deal with recently but they sound like a problem that I had with an early TDV8 that I had a few years ago - spent a shed load of money replacing things and the problem ended up being corrosion in the engine wiring harness in/around the multi pin connector to the main ECU. I did have a photo of the problem but I can't find it. Must be worth a look! |
If u find the photos that would be great buddy am getting so annoyed with it |
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 33 ![]() ![]() ![]() |
Cheers guys, I have p2290 and p0089 codes with fuel pressure regulator and regulator signal circuit short messages, what was your case eventually? |
One of the codes… |
One of the codes… |
In my case it was the high pressure fuel pump 3 bolts 30 min job un beleaveable got it off breaker link for £200 deliverd and it's never faulted since |
