Home > Technical (L322) > limp mode
v3mmtrangerover
United Kingdom 2008 Range Rover Vogue SE TDV8 Mariana Black
limp mode
Hoping someone might be able help with an ongoing problem with my 2008 TDV8 RR Vogue SE only done 82K
Driving along with no problems hit 40mph and then fault warning and the following list of faults come up: the RR has been with a independent land rover garage now for 3 weeks and still no joy he's pulled all injectors tested all sorts apparently has anyone got any idea or solution to the issue
Engine system Fault
Suspension Lowered
Transmission Fault - Limited Gears only
HDC Fault - system not available
I've searched YouTube and google but cant fined anything I have also had it plugged in but no joy on any tests that have been done sick as a chip now Big Cry Big Cry Big Cry
Post #556278 2nd Jun 2020 9:38pm
Dolphinboy
hhmmm, not sure as your faults cover a variety of sins .....
my initial thought is it's a battery or electrical fault, maybe even something so simple as a poor fitting earth or neg cable to your battery?
others with more knowledge and skill will be a long soon I imagine ... Embarassed
Post #556298 2nd Jun 2020 10:40pm
v3mmtrangerover
everything that has been suggested on the forum so far I have done so passed it to the garage and even he hasn't pined it down yet god knows how much its going to be billed for when/if he can even fix it sick isn't the word Big Cry
Post #556303 2nd Jun 2020 11:22pm
cass
What fault codes are showing?
Post #556375 3rd Jun 2020 4:23pm
v3mmtrangerover
P0913-Fuel rail pressure to high input
P0191-Fuel rail pressure sensor range/performance
P117D-Fuel volume regulator control exceeding maximum control limit
P2290-Injector control pressure too low
The RR is at a land rover garage and he’s done loads of tests but apparently still no future Big Cry Blody love the car
Post #556377 3rd Jun 2020 4:34pm
cass
They're not the codes I've had to deal with recently but they sound like a problem that I had with an early TDV8 that I had a few years ago - spent a shed load of money replacing things and the problem ended up being corrosion in the engine wiring harness in/around the multi pin connector to the main ECU. I did have a photo of the problem but I can't find it. Must be worth a look!
Post #556396 3rd Jun 2020 6:42pm
v3mmtrangerover
If u find the photos that would be great buddy am getting so annoyed with it Sad
Post #556402 3rd Jun 2020 7:47pm
Pal
Hungary 2010 Range Rover Vogue TDV8 Galway Green
Cheers guys, I have p2290 and p0089 codes with fuel pressure regulator and regulator signal circuit short messages, what was your case eventually?
Post #626645 21st Mar 2022 8:12pm
Pal
One of the codes…
Post #626646 21st Mar 2022 8:14pm
Pal
One of the codes…
Post #626647 21st Mar 2022 8:15pm
v3mmtrangerover
In my case it was the high pressure fuel pump 3 bolts 30 min job un beleaveable got it off breaker link for £200 deliverd and it's never faulted since
Post #626676 22nd Mar 2022 7:26am
