![]() | Home > Maintenance & Mods (L405) > dynamic mirror indicators |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
One other thing. On the part that illuminates are yours Stamped in the plastic “12v 5w” (Where it says DOT SAE etc)? 2014 FF Autobiography 5.0 SC
The packaging will be Powerfuluk's Stan... They try to keep a standard when being from them... So, those may have arrived in jiffy bags for all we know Stan ![]() |
I will be speaking to Simon @ Powerfuluk over the next few days Horse... So i will interrogate him for you sir ![]() |
Haha got a good chuckle from your reply Craig. It does look like different LED modules are being used in mine vs the ones you all got. Yours being more powerful LED. 5w is generally pretty bright for indicators. If we could get 10w that would be something! Oncoming traffic would need |
Any word guys? Yours definitely say 5w on them?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35845 ![]() ![]() |
says 5w on the box but cant confirm what it says on the light unit as its fitted but i assume it will also say the same... ... - .- -.
Confirmed with another member on the 5w....you can see it once installed...its by the DOT E yada yada stamp on the lens.
i had a look at the OE light and it has a small led at the front and the light is channelled down the perspex to the end ...i thought it had leds all down the light but it seems not.. ... - .- -.
Right...OEM are made to shoot the the light (rearward) down the channel So you see the light from the side of the car/coming up along side of it.
Well my second go around has hit the shores....let’s hope they don’t sit in NY for 1-2 weeks like everything else that’s imported 2014 FF Autobiography 5.0 SC
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Fingers crossed you get them ASAP! |
Hopefully by the weekend...but not keeping my hopes up 2014 FF Autobiography 5.0 SC
With any luck i should have mine tomorrow 2014 FF Autobiography 5.0 SC
Got mine today. Did notice the plug is backwards so It won’t snap in... Did any of you use electric tape or anything to hold the plug so it doesn’t disconnect and remove power from the unit? 2014 FF Autobiography 5.0 SC
