Home > Maintenance & Mods (L322) > Does this look like water ingress?
Long beep means fault with PDC (either module or sensors/wiring)
bumpers off job to check wiring and looms
also open up the PDC module, to see what , if anything, lurks inside
Are you sure someone didn't just spill a cup of coffee there ? (carpet stain) .
Post #553206 8th May 2020 9:43pm
Walter Skinner
Bulgaria 2019 Range Rover Autobiography 2.0 PHEV Barolo Black
This has been solved, thanks everybody who participated.
As suspected issue was with i-bus, turned out white/grey/yellow wire between instrument cluster & LCM itself was broken.
Happy it is solved. Unhappy that I've started to disassemble the car from the trunk. Well, at least gave her a good cleaning.
Post #558876 24th Jun 2020 6:10pm
Good news, glad to hear you got to the bottom of it and thanks for remembering to post the outcome...
Where was the break and how had it happened...??
Thumbs Up Pete
-Click here for Thread-
Post #558882 24th Jun 2020 6:31pm
Walter Skinner
Wire inflection left to the blower motor (LH vehicle), human factor aka previous repairs, I've discovered considerable amount of glass chips while inside the center dash, most probably windscreen was broken & replaced at some point.
Thanks for your pics Pete, they've brought my relations with the car on a totally different level Laughing
Post #558887 24th Jun 2020 6:52pm
Thumbs Up Thumbs Up Pete
Post #558889 24th Jun 2020 6:56pm
