Home > Off Topic > Home electrics - can use 3 x single 2.5mm vs. Twin & Ear
GGDR
Hi team,
A non- Range Rover question to any spark-types...
I need to add a 1 x double 13a socket as a spur to a ring.
There is a small gap to get a cable into the floor void needed for the run but a 2.5 T&E is just a shave too thick*
1.5mm T&E would fit but isn't rated highly enough in my view for even 1 x 13a double spur.
To save a load of destruction, does anyone know if can I use 3 x 2.5mm single core ?
The job would be infinitely easier if I can use the small access gap to feed the cable(s) into the void but this is just a feed point and once in the void there is plenty of room. Any cable won't be remaining in the access gap and therefore won't under any squeeze pressure.
I've seen multiple singles used in commercial wiring but I have not really come across them in domestic. Cheers, Greg
Post #559249 27th Jun 2020 4:51pm
Brian Considine
Sorry, in a word - no. The sheath must be continuous & enter all the accessories such as back boxes.
Put simply - single cables are used within trunking/conduit systems which effectively form the same purpose (mechanical protection) as the sheath that surrounds Twin & Earth type cables.
Having said that it would work but not comply.
(as for my qualifications - Qualified Electrical Engineer/HGV Driver/Industrial Firefighter.) 2003 Range Rover Vogue TD6
Post #559254 27th Jun 2020 5:34pm
GGDR
Ok perfect, thanks Brian.
I'll get my hole saw then.. Big Cry
Thumbs Up Cheers, Greg
Post #559255 27th Jun 2020 5:38pm
GGDR
Just a thought, would 2 x 1.5 T&E work ?
Or is that too much of a bodge?
Capacity would be sufficient, as would sheathing.... ?
. Cheers, Greg
Post #559258 27th Jun 2020 5:57pm
Deffo make the hole bigger.
As above you could wire it in conduit, but it’s not worth it for the sake of making an existing hole a tad larger.
If possible would it not be better to extend the ring to the double socket, rather than adding it as a spur. There is nothing that can't be fixed with a hammer😜😜
Post #559259 27th Jun 2020 5:57pm
Bigger hole is the right advice
Depending on how much of a pain that is - does the spur really need to be to a 2x13a socket ?
Could you put a fused spur next to the existing socket and then run 1.5mm off that to the new location and a single socket ?
Post #559262 27th Jun 2020 6:24pm
GGDR
Cheers Mark. Thumbs Up
The 'hole' isn't that simple more of a gap.
The hardwood finished oak floor is the thing I would have to drill and it's on show so trying not to do that....
Alistair - yes I could certainly that is an option. Thumbs Up
Been using this top tool:
https://www.amazon.co.uk/gp/product/B07SC5...&psc=1
 Cheers, Greg
Post #559263 27th Jun 2020 6:33pm
