![]() | Home > Maintenance & Mods (L322) > EGR blanking |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
If your EGRs are working OK, there should be no performance benefit - just piece of mind that if the EGRs break up, the bits won't get digested by the engine via the intake system.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Blank them with a £30 kit. Some engines throw up a fault light, some don’t.
Martyns Member Since: 24 Jun 2020 Location: Farnham Posts: 14 ![]() ![]() |
Do these have the swirl flaps ? I've heard they can also detach and merrily continue to engine causing issues ... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
No swirl flaps on the RRs. They were on the BMWs only. John
Brill that's one less thing to worry about |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
If yours is a 3.6 then go ahead, blank off the EGR.
3.6 = blank it off with a £30 ebay kit then remap it for some more poke.
booked in for preliminary check tomorrow, remap stage 1, egr delete and cap, gearbox remap... i see from receipts it had turbo hoses changed last year, but i will get them to have a look whilst in there...
Where is it being done? AJ Land Rover? Keith Gott's? Challenger 4x4? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Lipup Member Since: 14 Oct 2019 Location: Corsham Posts: 1 ![]() ![]() |
Mine has had the egrs blanked and a remap. The comment from an expert ‘... You won’t get any less smoke than that with th egrs blanked’ would have put me off if I heard it before making a decision. I’d be interested to know how smokey it is under acceleration. All the best hope it goes well. |
Had to move it to Wednesday, so will report back then .. |
Where is it booked in? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I've got a mobile mapper coming over at 9am he uses maps from elite remaps , I've bought the blanking plates but he says you don't necessarily need them as valves are shut off and disabled |
I'd do the blanks anyway. I'd trust a physical blanking plate over a mapped one all day long. Putting the blank plate in after the map should be OK. The ones where the the link pipe is removed and the ports blanked appear to be the "best" as they are a 100% sure way of stopping crap getting ingested |
