Home > Maintenance & Mods (L322) > EGR blanking
Neilacker
EGR blanking
Hi
I'm thinking of blanking off the EGR because I have read it will improve performance but will I need the iid tool to program it or will I need something else.
Thanks 2010 tdv8 vogue se, Buckingham Blue
Post #559434 28th Jun 2020 9:23pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If your EGRs are working OK, there should be no performance benefit - just piece of mind that if the EGRs break up, the bits won't get digested by the engine via the intake system.
PS Should have had said I have blanked our 2006 3.6 TDV8 after a mate had his 3,6 engine wrecked when 1 of the EGR valve heads broke up & were ingested by the engine ! Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #559435 28th Jun 2020 9:37pm
DrRob
Blank them with a £30 kit. Some engines throw up a fault light, some don’t.
IID is useful for all sorts of reasons including have the engine fault light mapped out. Bell Auto Services can supply the IID and the map.
Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #559436 28th Jun 2020 9:59pm
Martyns
Do these have the swirl flaps ? I've heard they can also detach and merrily continue to engine causing issues ...
Post #560046 3rd Jul 2020 8:19am
Weegie
No swirl flaps on the RRs. They were on the BMWs only. John
GAP iiD BT
Post #560054 3rd Jul 2020 9:34am
Martyns
Brill that's one less thing to worry about Smile
Post #560066 3rd Jul 2020 10:49am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
If yours is a 3.6 then go ahead, blank off the EGR.
If it's a 4.4 then don't as the DPF uses the EGR cooling after a regen.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #560072 3rd Jul 2020 11:26am
DrRob
3.6 = blank it off with a £30 ebay kit then remap it for some more poke.
Change all turbo hoses for silicone ones. 3.6 is known for weak hoses that can breakdown internally and then get sucked into intake. Not good. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560073 3rd Jul 2020 11:29am
Martyns
booked in for preliminary check tomorrow, remap stage 1, egr delete and cap, gearbox remap... i see from receipts it had turbo hoses changed last year, but i will get them to have a look whilst in there...
im lucky this one has had two new turbos , so hopefully the remap wont put too much extra pressure on them, but it wont be to drive it like its stolen anyway, just fancy a wee bit more poke, and less lag , not that there's a lot, just a tad on pulling away
Post #560078 3rd Jul 2020 12:04pm
DrRob
Where is it being done? AJ Land Rover? Keith Gott's? Challenger 4x4? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560080 3rd Jul 2020 12:10pm
Lipup
Mine has had the egrs blanked and a remap. The comment from an expert ‘... You won’t get any less smoke than that with th egrs blanked’ would have put me off if I heard it before making a decision. I’d be interested to know how smokey it is under acceleration. All the best hope it goes well.
Post #560097 3rd Jul 2020 3:03pm
Martyns
Had to move it to Wednesday, so will report back then ..
Post #560426 7th Jul 2020 2:09am
DrRob
Where is it booked in? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560432 7th Jul 2020 7:55am
Martyns
I've got a mobile mapper coming over at 9am he uses maps from elite remaps , I've bought the blanking plates but he says you don't necessarily need them as valves are shut off and disabled
Post #560585 8th Jul 2020 8:42am
DrRob
I'd do the blanks anyway. I'd trust a physical blanking plate over a mapped one all day long. Putting the blank plate in after the map should be OK. The ones where the the link pipe is removed and the ports blanked appear to be the "best" as they are a 100% sure way of stopping crap getting ingested Big Cry
https://www.ebay.co.uk/itm/RANGE-ROVER-Vog...2642302772
Keep us posted Thumbs Up
Also, change engine oil and filter once between annual services. Best way to keep engine clean and preserve turbos Bow down 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560588 8th Jul 2020 9:16am
