![]() | Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2263 ![]() ![]() ![]() |
Ahh sorry yours is dsp not logic 7?
ChrisRRV Member Since: 30 Jun 2020 Location: Belfast Posts: 104 ![]() ![]() ![]() |
Sorry I'm HK logic 7
I’m Confused I didn’t rip the amp out on logic 7 I did that on dsp on logic 7 I used a hur adapter.
Sorry my fault on the confusion it's been a long day lol
No other way around - if it is optical you do need hur if it’s not I think you can wire directly in Current stable:
Anyone any pics of the wiring to tell whether I have the optical connected HK system |
Got bad news on my unit its a MY05 MOST range
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
Your MOST system is the same as in Dan's 2007 with Logic 7, so you could probably go down the route he has taken. John
@Danwilderspin do you have a link to the HUR box you bought |
https://avinusa.com/most-fiber-optic-amp-i...ander.html
Thanks alot Dan ill get one ordered up to go with the same Erisin unit you went for |
Dan one final thing did you need a fasica unit for your erisin unit? Or does it fit perfectly? |
Hi Chris - the Erisin I have is different to that one (mine is a year old now and they churn these out quick) mine had the traditional CD player backing to it as opposed to the tablet style. Mine in the 2002-05 went in fine there is a a massive cavity behind it but if it’s loads thicker you may need to get a bit handy with how you mount it. I didn’t need anything else tbf I bought a 5m most cable as I’m lazy and couldn’t be bothered to reroute what was there I think it was about £20 from Ali express Current stable:
Just remember you won’t be able to set the clock as this is set through the screen unless you buy a resler interface and a licence of ibus app.
