![]() | Home > Technical (L322) > A/C Leak |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
My 2003 L322 was regassed a couple of weeks ago as it wasnt blowing cold.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Yep, 9 times out of 10 it is the condenser that fails, less than £100 and easy enough to change... |
Nice one, thanks Haylands. 2010 L322 Autobiography Black Edition
If the OP can see the leak then he may as well fix it properly, leak sealer is a temporary repair which as you have found can work for a long time..... sometimes.... Pete
zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79 ![]() ![]() ![]() |
Had exactly the same problem about 3 weeks ago. I though it might be the condenser but local specialist diagnosed a corroded pipe which was £49. 2017 4.4 TDV8 Autobiography
OP said the leak was at the front of the condenser in various places, the pipes are on one side only and at the top so I expect it's the condenser.. |
