Home > Technical (L322) > A/C Leak
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
A/C Leak
My 2003 L322 was regassed a couple of weeks ago as it wasnt blowing cold.
On the journey home and over the next couple of days it was lovely and cold.
A week afterwards it didnt appear to be blowing cold, so it went back and they went over the whole lot with a lot of dye and spent ages looking for leaks and nothing found.
...again, a couple of days later and its not blowing cold, so it has got a leak somewhere.
Tonight I went outside with a UV light and had a look for myself. I reckon I can see small areas of the dye at the front of the AC rad in various places.
Is this a fairly common problem, and are the joints to the rad easy to seal up if I replace it?
Cheers
Neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #559709 30th Jun 2020 11:17pm
Yep, 9 times out of 10 it is the condenser that fails, less than £100 and easy enough to change... Thumbs Up Pete
-Click here for Thread-
Post #559711 30th Jun 2020 11:21pm
24valve
Nice one, thanks Haylands. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #559712 30th Jun 2020 11:23pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Clearly you have a very small leak. It is likely, this could be fixed with a sealant from Halfords. Our Smart car used to lose all air con efficiency over a 4 month period. I used the sealant, and 6 years later, it's still going strong. It's in Corfu so during the summer, you have to have efficient air con. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #559716 1st Jul 2020 7:12am
If the OP can see the leak then he may as well fix it properly, leak sealer is a temporary repair which as you have found can work for a long time..... sometimes.... Pete
Post #559833 1st Jul 2020 9:05pm
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
Had exactly the same problem about 3 weeks ago. I though it might be the condenser but local specialist diagnosed a corroded pipe which was £49. 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #559838 1st Jul 2020 9:15pm
OP said the leak was at the front of the condenser in various places, the pipes are on one side only and at the top so I expect it's the condenser.. Thumbs Up Pete
Post #559840 1st Jul 2020 9:21pm
