Home > Technical (L322) > Hitachi compressor still unrepairable?
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
I read many comments Hitachi s don’t do good when repaired.
Is it still the same?
I saw same kits on flea bay. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #560128 3rd Jul 2020 9:36pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I used this kit and it was certainly working better afterwards.
http://4x4airseals.com/product/air-suspens...pair-kit-2
It still occasionally throws the "normal height only" message, but quite rarely and I think I might have tightened the end of the drier filter too much, strangling it a bit.
Post #562372 22nd Jul 2020 5:44pm
I had problems with mine, tried the repair kit, didn’t work, so ended up buying a new one from E-bay at slightly more than the repair kit.
You pays your money and all that Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #562399 22nd Jul 2020 11:22pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
I rebuilt mine and it works great. Best bet is to do the desiccant and filters first and only do the pump if that hasn't solved your issues. Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #562404 23rd Jul 2020 8:17am
NDT
I’m resigned to having to replace mine.
I’ve loosened the filter in the desicant container but it’s still throwing the error.
Pump runs for up to a minute on startup then throws the error message. System doesn’t lose height overnight so I’m assuming there’s no leak.
I assume it’s either timing out or overheating before it manages to refill the air reservoir.
The pump has got some white writing on it - like a breaker might do if supplying a second hand unit... so I wonder whether it’s an old one.
Post #562727 26th Jul 2020 4:16pm
NDT
Any recommendations on which replacement to buy?
Post #562729 26th Jul 2020 4:50pm
procee
Is there any way to tell which compressor you have without taking it out? I have a horrible feeling mine is needing replaced.
Post #563237 31st Jul 2020 5:07pm
umitbat
Open the cover.
Probably you can see which one by looking the back of compressor(cabin side). 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #563748 6th Aug 2020 8:45am
umitbat
I drilled a hole on copper filter.
And after the faulty bag is changed it is OK no heating.
It was untouchable so hot once so I believe Hitachi is more durable comp. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #563749 6th Aug 2020 8:48am
