Home > Technical (L405) > Oil sump drain bolt seized
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Sdv8 Well and truly stuck. Now almost rounded. Any tips and due too tight access can see very few options other than heat? 13mm head steel into alloy a common problem I suspect!
Post #560147 4th Jul 2020 4:01am
GraemeS
Australia
Can you knock a 12mm ring spanner or socket onto it? You might want to have a replacement on hand before you remove it though.
Post #560150 4th Jul 2020 5:27am
Do you have a hot air gun by any chance? More gentle than gas but could well work.
Post #560154 4th Jul 2020 8:01am
bleeperman
Sump
No space to knock an undersize on really. Will try heat gun. Thanks
Post #560160 4th Jul 2020 9:11am
suck the oil out?? ... - .- -.
Post #560166 4th Jul 2020 9:27am
DrRob
Draper Expert 10L vacuum pump is the dogs Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #560173 4th Jul 2020 10:11am
Baltic Blue
+1 with Stan, get a syphon pump, you will never do an easier, cleaner, quicker oil change, and never need to struggle getting the sump plug out again.
Mike.
Thumbs Up Rob, you beat me to it. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #560174 4th Jul 2020 10:11am
To be fair, JLR made/installed the service tube to suck the oil out... They were never designed to drop the oil out from below... Thumbs Up
Post #560181 4th Jul 2020 11:27am
mjdronfield
Yes.... what are you doing rolling about underneath it?
Thatโ€™s not really helped I know.... leave it well alone, do the oil change as above.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #560187 4th Jul 2020 11:48am
And for anyone reading this in the future? Only ever use a 5 sided wrench/spanner/socket to loosen any sump bung! ๐Ÿ‘
Post #560191 4th Jul 2020 12:07pm
GraemeS
Australia
5 sides? How about single hex rather than double hex or 12-point?
Post #560195 4th Jul 2020 12:27pm
bleeperman
I gave in and the sump guard was enough to dent my ego! Steel and aluminum never a good match!
Always like to do oil properly, you never fully empty the oil via syphon. My local guy did get it out on the ramp but he did make the air blue! Help got CAR OWNER VIRUS!
Post #574945 3rd Dec 2020 2:08pm
ur20v
A Trap
Get someone with a TIG (or a MIG) to weld a 17mm nut on the sump plug. The heat will help release the plug and the larger spanner size will help allow more torque ๐Ÿ‘
Post #574949 3rd Dec 2020 2:37pm
But the engine was designed to have the oil sucked out! If you suck the oil out then remove the sump bung, you won't get much more than an egg cup of cleanish oil out! Thumbs Up
Post #574954 3rd Dec 2020 3:26pm
knwatkins
Of course they were designed to have the oil dropped from below, Craig. That's why the sump plug is there Wink
They were designed to have the oil drained via either methods.
It's worth mentioning that in marine engines, the oil is always sucked out because there is no way to drop it out from below. It is a safe enough method of changing the oil.
Personally, I always drain from below because I take the opportunity to have a look around and check everything is in order at the same time.
Horses for courses. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #575008 3rd Dec 2020 10:04pm
