Home > Technical (L405) > Rear door issue
m11rphy
Rear door issue
Hi guys,
I have a 2013 SE and Im have a starge issue with the rear driver side door, these are issue
Window wont open using the switch on the door or the drivers door switch
The door cannot be opened from the inside
The door can be opened from the outside if the key is your hand or pocket as you pull the handle, door will no open when keep is not in range.
I have checked the fuses and all are good, anyone have any ideas?
Post #560803 9th Jul 2020 4:12pm
i'd be tempted to take the door card off and see if there are any loose connections or maybe water ingress.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #560804 9th Jul 2020 4:19pm
pld118
1. Have you tried to see if all 4 windows open and close by depressing and holding the unlock/ lock button on the remote keyfob?
2. Also, see this information which related to the front passenger door on ours:
LR Extended Warranty - Covered Replacement Front Passenger Door Latch / Mechanisim
March 2020
https://www.fullfatrr.com/forum/post545480.html#545480
Note - the other day, our front passenger door would not open again from either inside or outside of the car. I got out, walked to the passenger door and pressed the lock button on the remote key fob twice (until the car made that locked/ folded mirrors/ bleep sound)... then I pressEd the unlock button on the remote fob and normal service/ use was resumed. I don’t know why that happened though and might take it back to the main dealer as the warrant work was only down a few months ago.
Post #560806 9th Jul 2020 4:43pm
m11rphy
My car has never been able to do this, should it be possible?
I will check out you thread thanks
Post #560807 9th Jul 2020 4:50pm
pld118
Yes, all 4 of our windows will open fully and close fully by depressing key fob buttons.
Is your car battery working okay?
Post #561096 12th Jul 2020 6:07am
pld118 wrote:
Note - the other day, our from passenger door would not open again from either inside or outside of the car. I got out, walked to the passenger door and pressed the lock button on the remote key fob twice (until the car made that locked/ folded mirrors/ bleep sound)
Ryan, if you go into your CCF files using your IID, switch on super locking single press... This negates the need to press the lock button twice to "super lock" the car... Thumbs Up
Post #561122 12th Jul 2020 12:06pm
pld118
Thanks Craig Thumbs Up
Post #561131 12th Jul 2020 1:04pm
Yes it is Martin... Thumbs Up
Post #561142 12th Jul 2020 2:23pm
Re: Rear door issue
m11rphy wrote:
Hi guys,
The wiring plug for that door is literally just where the loom goes into the pillar... if you open the plug and check the connections are clean etc etc Thumbs Up
Post #561143 12th Jul 2020 2:26pm
