Home > Wheels & Tyres > Wheels and tyres advice
EnVogue
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Hi all. Be grateful for your advice on a set of 22 inch wheels I'm thinking of buying and whether they will fit my L322 without any danger of rubbing. They have the following size:
22x9.5
Et30
5x120
74.1 Centre bore
Tyres are all 275 40 22, but was wondering if 285 40 22 or 285 35 22 tyres would fit.
Thanks guys
Post #545635 1st Mar 2020 9:00am
ET30 sounds way off
From my Limited knowledge,the L405 22” wheels are 22x9.5 ET49. The SVR L494 wheels are 10” wide with an offset of 42.5.
The L405 wheels fit the L322
Post #545638 1st Mar 2020 9:09am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Sounds way off.
Post #545650 1st Mar 2020 11:25am
Brian Considine
I take it you have checked the load rating of the wheels & tyres ? 2003 Range Rover Vogue TD6
Post #545652 1st Mar 2020 11:56am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I’m pretty sure that my 9.5J 22” are ET45. They run nice and even with the body work. Just right I would say. Naturally it depends a bit on the wheel design but I would think ET30 would appear to far out for the car and go beyond the wheel arches.
Post #545656 1st Mar 2020 1:04pm
EnVogue
Thanks for the replies guys. These are the wheels I was looking at:https://www.ebay.co.uk/itm/163927889553
Maybe I'll just look for a cheapish set of Overfinch alloys to come up for sale
Post #545689 1st Mar 2020 6:04pm
EnVogue
Thanks Mark. That's a lovely set of wheels you've bought. I think I'll keep browsing for something more suitable
Post #545713 1st Mar 2020 8:42pm
Bl4ckD0g
Shouldn’t be anything wrong in principle with aftermarket wheels if they are are made to certain standards.
Besides the normal load bearing suitability I do also tend to make certain they are TüV and JWL certified.
I’d be surprised if Manufacturers like Revere, Khan, Overfinch and Hawke to name a few aren’t up to the standards.
Post #545718 1st Mar 2020 9:35pm
Brian Considine
The problem with load ratings is when people fit wheels, branded or otherwise to RR's that were intended for cars.
Seemed to be quite an issue with VW T5's. 2003 Range Rover Vogue TD6
Post #545772 2nd Mar 2020 12:47pm
Bl4ckD0g
Sometimes it’s just the luck of the draw. I had it twice with my Golf R official wheels. Just a pothole I went straight in Sad
Post #545782 2nd Mar 2020 1:33pm
EnVogue
Hi guys. Just by way of an update, I managed to buy a set of 22 inch overfinch olympus alloys off eBay. They are currently shod with 285/35/22 budget tyres, but I will 285/40/22 tyres will fit my 2005 vogue without any rubbing issues?
Thanks
Post #561252 13th Jul 2020 1:03pm
2005 was a crossover year - check your nuts
Nuts need to match the wheel, so yours may be the earlier ones or later.
https://www.fullfatrr.com/forum/topic1262-15.html
Post #561312 13th Jul 2020 8:16pm
EnVogue
Thanks guys. I've got silver wheel nuts fitted at the moment, so fingers crossed they'll be ok for the new wheels.
Post #561315 13th Jul 2020 9:11pm
EnVogue
Well I finally got the overfinch alloys fitted with 285/40/22 tyres. Any ideas what the right tyre pressures should be?
Post #563975 8th Aug 2020 6:38pm
