Home > My Range Rover > Cold Turkey over, think I've found my next one!
Page 3 of 5 <12345>
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Glad it helped Thumbs Up 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #544258 17th Feb 2020 10:24pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Another thank you from me , my son dis the job for me and I guided with your instructions , the L405 is a little different but the guide helped tremendously. I don't think mine was leaking but the old gaskets were flat with hardly any lip protruding from the groves, the new gaskets had quite a lip so hopefully the cooler is all good for a while yet. I changed the 2 o rings on the oil cooler feed and it was difficult enough to get back in requiring quite a bit of persuasion .
Thank you for your guide. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #557834 15th Jun 2020 7:56pm
mm289
No probs Very Happy
Paul. 2011 TDV8 AB
Post #557885 16th Jun 2020 10:27am
Leesbay
England 2011 Range Rover SE TDV8 Zambezi Silver
Big thankyou to Paul for the brilliant guide which helped no end with doing this job today
Took me 6 hours, a lot of which was cleaning the gunk out of the various parts, then cleaning up the mess on the drive😂
A few fiddly bits but nothing most cant do with an 8mm and 10mm socket just follow the guide👍
A little coolant leaked as i pulled the oil cooler so changed the oil at the same time
New silicone donut hoses added for good measure
Mines a 66k 2011 and had just started sweating oil from the top cooler gasket so Im glad i did it as a preventative measure. viton turbo pipe o rings done again too As you need to disconnect the pipe anyway
Old gaskets were very hard and flat so definitely recommend anyone with an older or higher miler to do this job before it goes to far and the coolant and oil mix
Millers c1 (10litres) oil, gen LR filter and the 2 oil cooler gaskets came in at £120 so a lot of satisfaction and maintenance for little outlay
Post #562156 20th Jul 2020 8:22pm
longd
Who did you buy the parts and oil from??
@Paul thanks so much for the write up I have an oily expansion btl so I assume I have the same issues so will get cracking once I get the parts etc I changed the turbo o rings last night as oil was badly leaking out of the back but after seeing oil in the expansion bottle I assume this is also needing doing lol
Post #570814 24th Oct 2020 12:39pm
paul70
Thanks Paul for this brilliant write-up, much clearer than the workshop manual. Managed it in around 3-4hrs in total off and on as the weather permitted. (Fitted new cooler as had stripped thread to oil pipe at rear) Having said that plenty of breaks needed as quite awkward at times. I could have done to have been a foot taller! Took for 40 mile round trip this morning and all appears OK.
Paul.
Post #578969 8th Jan 2021 12:04pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
great write up!!
will be doing this job very soon 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #578976 8th Jan 2021 1:58pm
mm289
No worries chaps, now have another 20k miles on the RR since this and still going strong Very Happy
Not much of it recently mind Big Cry
cheers,
Paul 2011 TDV8 AB
Post #579055 9th Jan 2021 11:49am
Jayk69
Hi sorry for the dumb question, excluding the ) rings are there x2 gaskets required for this job?
x1 block to cooler base part no LR077242
x1 Oil cooler to base ? part no ?
i cannot seem to see the part no for the second one i assume as it is bits you do the lot.
any help appreciated 2012 Vogue 4.4 TDV8 - Current
Post #579835 15th Jan 2021 10:08am
Jayk69
Do not worry i re-read the thread found the part no
LR022903
Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #579841 15th Jan 2021 11:03am
Jayk69
soooo just got car back having had all belts and pullies changed and was told there was spots of oil in coolant Shocked oil cooler is leaking so i need to bring this forward now. for speed i have just ordered a new cooler too so it will be just a swap out rather than a big cleaning job as well. 2012 Vogue 4.4 TDV8 - Current
Post #582207 3rd Feb 2021 9:23am
Jayk69
new cooler arrived today Thumbs Up
Post #582472 5th Feb 2021 11:44am
Jayk69
so i am just part through this job took me 1.5hrs to remove the intake (Got my 11 year old helping) so i reckon it would take me an hour on my own.
intakes are well horrible gonna vac out and scrape as much as i can off the inlet manifolds the inlet i can do on the bench.
Instructions are first class so far really impressed has made the job so much simpler.
cuppa tea then off to remove the oild cooler itself which has been leaking for sometime i guess. I am just swapping out for a new one Thumbs Up
will update when done 2012 Vogue 4.4 TDV8 - Current
Post #584429 19th Feb 2021 11:22am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Good luck with the job, well worth doing yourself, just remember that when fitting the new one, the bolts don't need to be super tight. WM states 13nm for torque. Thumbs Up 2011 TDV8 Vogue SE
Post #584430 19th Feb 2021 11:30am
Jayk69
Thanks for that they were not tight in any how.
have just finished some lunch so onto the re-fit now there is a bit of cleaning to do too. took a good 30 mins to clear up all the oil and coolant sucked it all out with a meat baster (The wife is not impressed!)
So now onto the re-fit Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #584442 19th Feb 2021 1:04pm
Page 3 of 5 <12345>
