|  | Home > Maintenance & Mods (L322) > P0846 egr fault code |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284      | The code P0486 indicates a "B" circuit malfunction, so check the EGR sensor connector for corrosion, bent or pushed out terminals or loose connection
|  27th Jul 2020 10:56pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284      | double post   | ||
|  27th Jul 2020 11:00pm |
| paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44      | Thank You Dolphinboy for the info , I think this might be a bit much for me to do , we do have a local Indy though .I also have P0404 which I've read about on here but it's been no problem for 2 years with me . | ||
|  28th Jul 2020 10:47am |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284      | this may help.
|  28th Jul 2020 11:07am |
| paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44      | useful info on the throttle body , i don't have any issues pulling away etc so i don't suspect any trouble with the body . Is it much of a job stripping the engine top down to get to the egr ? , i think the valve itself is probably sticking . I have cleaned the maf sensor housing as it was gunged up when i serviced the engine back in March .
|  28th Jul 2020 2:46pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781    | The EGR valve can't get to be the same condition as the MAP sensor because there's no oil in the mix, only carbon. The muck that accumulates in the intake has oil from the turbos and carbon from the exhaust but the EGR valve only gets the carbon. However EGR valves can get stuck from just the carbon. | ||
|  31st Jul 2020 10:55am |
| paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44      | Thought I would share the outcome of my P0486 code issue . Having gone through the usual checks for air leaks etc and having found nothing wrong I bit the bullet and took it to Duckworths . . Initially nothing was reported as wrong , the Technician I spoke to noticed something slightly unusual with the sensor on the throttle body but in his opinion nothing to spark my code .
|  7th Sep 2020 7:22pm |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | Do you mind me asking how much the throttle body was Paul? | ||
|  7th Sep 2020 8:18pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | not the first throttle body replacement I've read about.
|  7th Sep 2020 8:37pm |
| paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44      | The throttle body was about £125 from memory , it's the labour and vat that spoils main dealer experience for me . I was very pleased with the technician at Duckworths though , they do love there Landrover's , showed me round workshops very impressive. 2011 tdv8 4.4 vogue Santorini black | ||
|  8th Sep 2020 8:48am |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564    | I had a freelander which threw a EGR circuit B error  a few years ago ... it also turned out to the throttle body.
|  8th Sep 2020 9:16pm |
| Posting Rules
