Home > Maintenance & Mods (L405) > Deployable towbar seized
Chad11
United Kingdom 2015 Range Rover Vogue TDV6 Causeway Grey
Has anyone else had towbar seize in the withdrawn position. To be told by Landrover that the complete fitting needs replacing ? Sad
Post #562925 28th Jul 2020 7:06pm
Has it seized or has the motor packed up ?
I'd try getting under there with some penetrating oil as a first attempt
Post #562929 28th Jul 2020 8:07pm
Chad11
My local dealer told me it was seized- I tried to use the towbar after a few months of lock down to hear the usual whirring sound momentarily then it stopped Ieaving me with a permanent beeping sound !
Post #562936 28th Jul 2020 8:28pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Powerful UK have a Youtube video on the tear down of this item. The problem they had was a missing tooth on a gear, which had jammed the mechanism. If I remember correctly, they sourced a replacement part (rather than the whole assembly) and all was well.
Post #562938 28th Jul 2020 8:51pm
supershuttle
 Geoff
Post #562947 28th Jul 2020 11:40pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Interesting exercise. Not cost effective for the dealership to strip the whole thing down and replace just the gear but it would be reasonable for them to replace just the gearbox.
This should be the difference between a mechanic, a technician and an engineer. The mechanic replaces the whole tow bar assembly, the technician replaces the gearbox and an engineer designs the whole assembly. It somewhat proves most stealers employ muppets. letters not necessarily in the right order
Post #562949 29th Jul 2020 7:51am
It’s what’s cost effective for the dealer at the end of the day! If they fit a new complete unit then they will have recourse with the tow bar manufacturer... If they fitted one new part And then another fails, the area of blame then get blurred somewhat!
It all depends on weather you have the skills or can employ someone with the skills to fix the said problem? Worth a try first imho sir... 👍
Post #562961 29th Jul 2020 10:16am
Dixy
Valid points, it would be reasonable for a dealer to replace just the actuator. letters not necessarily in the right order
Post #562985 29th Jul 2020 12:59pm
Ocean53
United Kingdom 2018 Range Rover Vogue SDV6 Corris Grey
Mine seized and, yup, complete new tow bar
Post #563028 29th Jul 2020 8:25pm
