Home > Technical (L322) > Power steering using vacuum pump.
nino_nino
. power steering flush using vacuum pump.
if you have vacuum pump you can use it to flush/change steering fluid in your car. you will need 2 L of fluid ( I use Pentosin/FUCS 202.), plug of some sort to plug return line connection and a means to connect vacuum pump to the return hose. that is it.
First suck all fluid from reservoir, there is going to be about a finger of fluid left on the bottom due to mesh on the bottom of the reservoir. unscrew bolt holding windscreen washer fluid reservoir so to gain some space when removing return pipe on the bottom of fluid reservoir. (smaller of the two hoses is return). use pliers to move spring clip down the hose and remove hose. put cap on the nipple, fill reservoir with fluid, connect vacuum to the rubber hose and watch fluid go down. keep adding fluid as needed. when you see clear fluid coming out you are done.
unplug vacuum, take plug off the reservoir (use finger to stop fluid from escaping) and reattach return hose. fill reservoir to the mark and that is it. start the car, turn steering wheel full left to full right
this was the first time I've change fluid, second time I went a step further, after sucking fluid from reservoir I used flashlight to check inside and I could see debris on the mesh, so removed the reservoir (it is held in place by conus metal slide, wiggle it while pulling up-watch your fingers - if you remove air filter box/held by three rubber grommets/ it will give you plenty of space to work) and given it a good wash with brake cleaner spray. as you can see from the pictures -good as new. put reservoir beck on and repeat above procedure.
pictures in the next post.
Nino,
Post #481998 27th Jun 2018 4:36pm
GGDR
Nino as I said before you're impressively equipped for anything.
And you document everything for others to learn from.
I nominate you for member of the year!
Can I bring mine to you?
You should start a business!
Looks great and a wiki entry right there?
Thumbs Up Thumbs Up Thumbs Up
Greg Cheers, Greg
Post #482047 27th Jun 2018 10:36pm
nino_nino
With air box out = planty of space to take out power stearing reservoar for cleaning.
job done, i do not know how necessary this is - but i does make me feel good knowing it is clean. Very Happy
Nino.
Post #482062 28th Jun 2018 4:39am
Balloonengineer
Nice writeup
Just a quick point is you mention brake fluid to clean, and what you mean is brake cleaner aerosol. (as in the pic)
Somebody else might take the text literally without thinking!
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #482073 28th Jun 2018 9:50am
nino_nino
Thanks, good point, corrected Thumbs Up
Nino,
Post #482074 28th Jun 2018 10:15am
DrRob
Can PAS fluid be changed by just siphoning off the reservoir multiple times over a few days then topping up/lock to lock every time it's siphoned off? I don't have the skills to replicate Nino Whistle Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #562951 29th Jul 2020 8:27am
Yes, I have done that successfully on my TDV8 and my Volvo. I used a large syringe with a bit of pipe to suck the fluid out of the reservoir, filled reservoir with new fluid, then used the car for a bit to circulate fluid, then repeated until fluid was clear. I did this over a few days.
Won't be as clean as nino's efforts though Thumbs Up .
Post #562954 29th Jul 2020 9:34am
DrRob
Thanks Joe! I'll give it a go. I'm patient... Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #562955 29th Jul 2020 9:41am
Baltic Blue
Rob,
How much fluid should I buy ? and how many times did you suck and refill ?
I have never changed mine before on all 4 I have owned, so I am all ears to any advice / tips.
Cheers
Post #633516 2nd Jun 2022 9:08am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I do the same work, but littlebit differently.
Everithing was the same as Nino doing until the vacuum pump. I didnt use it. I lift up both front wheels and turn the steering wheel from left end to right end couple times. During turning old oil just come out from the return line and new go in same way as Nino-s.
By doing so you can be sure that steering gear is also compleatly empty from old oil.
NB: remember not to start the engine during that procedure! Only ignition (to unlock the steering wheel)!
Post #644305 29th Sep 2022 1:02pm
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
That's almost true, except that engine must be indeed running to flush the system completely. 4l new fluid is needed for that. And attention is needed not to let the fluid level in reservoir get too low while flushing, because with engine running the pump is moving this fluid really fast!
Quote from 4.4 TDV8 workshop manual:
Flush the power steering system.
9.
Start the engine
With assistance turn the steering slowly lock to lock 3 times at approximately 1 revolution every 5
seconds.
Continue to flush the power steering system until 4 liters of power steering fluid has been added to the
power steering reservoir. This should take approximately 30 seconds
Post #647598 7th Nov 2022 3:51pm
jaguar3
Thatwhy I didnt start the engine, to avoid get air in system. It suck oil really fast.
I dont see any reason why need to start the engine (maybe if not lift wheels up from the ground). Oil go anyway through the oil pump, is it running or not.
Post #647601 7th Nov 2022 5:47pm
kokamagi
And I add that the inner diameter of the return hose is 10mm if someone is preparing for the job.
Post #670321 2nd Aug 2023 5:18pm
