Home > Technical (L322) > Power steering using vacuum pump. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Nino as I said before you're impressively equipped for anything.
27th Jun 2018 10:36pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
With air box out = planty of space to take out power stearing reservoar for cleaning.
28th Jun 2018 4:39am |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 171 |
Nice writeup
28th Jun 2018 9:50am |
Thanks, good point, corrected
28th Jun 2018 10:15am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4218 |
Can PAS fluid be changed by just siphoning off the reservoir multiple times over a few days then topping up/lock to lock every time it's siphoned off? I don't have the skills to replicate Nino 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Jul 2020 8:27am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Yes, I have done that successfully on my TDV8 and my Volvo. I used a large syringe with a bit of pipe to suck the fluid out of the reservoir, filled reservoir with new fluid, then used the car for a bit to circulate fluid, then repeated until fluid was clear. I did this over a few days.
29th Jul 2020 9:34am |
Thanks Joe! I'll give it a go. I'm patient... 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Jul 2020 9:41am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Rob,
2nd Jun 2022 9:08am |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
I do the same work, but littlebit differently.
29th Sep 2022 1:02pm |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 |
That's almost true, except that engine must be indeed running to flush the system completely. 4l new fluid is needed for that. And attention is needed not to let the fluid level in reservoir get too low while flushing, because with engine running the pump is moving this fluid really fast!
7th Nov 2022 3:51pm |
Thatwhy I didnt start the engine, to avoid get air in system. It suck oil really fast.
7th Nov 2022 5:47pm |
And I add that the inner diameter of the return hose is 10mm if someone is preparing for the job. |
2nd Aug 2023 5:18pm |
