Home > Technical (L322) > Intake manifold planum chamber rear nearside oil misting.
Page 2 of 3 <123>
Baltic Blue
: https://www.fullfatrr.com/forum/topic44115.html
Rolling with laughter
You should read the above post and you will see most of the common issues
Glad you are sorted so easily.
Post #563713 5th Aug 2020 6:24pm
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Read and completed.
Thanks
Neil
Post #563719 5th Aug 2020 6:38pm
DrRob
Great news Thumbs Up
Don’t drive it too far or you risk DPF filling up too fast Whistle
Keep us posted Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #563721 5th Aug 2020 6:58pm
neilly
no quoted added....redone
Post #563723 5th Aug 2020 7:03pm
neilly
Why would the DPF fill up too quick?
Thanks
Post #563724 5th Aug 2020 7:03pm
neilly
double posted....oops
Post #563725 5th Aug 2020 7:15pm
Baltic Blue
Neil,
Trust Rob, he is right.
Every time DPF warnings become a problem, they are caused by air leaks in the intake...the plenum hoses are the biggest cause, followed by leaks on the throttle body hose, then splits in the plastic manifolds or the plenum .
Get it changed before you fill the DPF.
You only have to read the catalogue of posts from previous failures to get the facts.
Post #563729 5th Aug 2020 9:06pm
neilly
OK, good to know thanks,
It is still doing DPF burns on the GAP IID.
I will keep an eye on it. I did superglue the hole closed. So will see how it lasts over the next few days.
Thanks
Neil
Post #563731 5th Aug 2020 9:17pm
DrRob
Trust me. I'm a Dr Whistle Rolling with laughter
Looking forward to seeing your nice bright pink/yellow/green Shocked hoses in place Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #563753 6th Aug 2020 9:45am
neilly
Haha, I ordered black.....
I only use coloured Silicone of the Defender..LOL
Thanks
Post #563754 6th Aug 2020 9:51am
neilly
Well that is annoying, order black and get blue.
So gave them a call and told the supplier I was using the parts but expect to be replacing them.
But got them fitted.
Biggest PITA was the connector shown here, not sure how that is meant to be removed, as I could not get it off.
Thanks again for all the help will have another go when the replacement black stuff turns up.
Post #563820 6th Aug 2020 9:17pm
DrRob
Shiny Thumbs Up
I’ve got blue on my 200Tdi Classic Thumbs Up
Did you cut to length or are they ready cut? Be good to post details for benefit of others in future Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #563823 6th Aug 2020 9:51pm
neilly
It came in a 950mm length,
Was the quickest way to get it next day from Amazon prime. From AutoSiliconehose.
Used a 3 inch glass cleaning blade to trim to length, one thig to make sure is not to make any longer than the original parts.
Be aware the inside of the plenum is a dirty place, so kae sure you have plenty of paper and brake cleaner to clean thign as you go.
The small male torx bolts that hold the front plate down can be undone with a 4mm 6 sided socket. If you do not have the correct torx fitting.
The 3 x 10mm headed bolts that hold the plenum chamber to the front plate , it is best to have 10mm ratchet spanner, this makes life slightly easier.
The bolts that hold you remove are slightly different lengths so take care of where they go.
If you use 70mm silicone pipe then a spray of a lube helps them sldie over the intakes, I used silicone spray as I had some in the garage.
BE VERY CARFUL with the the jubilees , the original ones have a flat plate on the screw area, if you releas e them too much this can fall off. There is a small risk of it going in the inlet manifold!!
Not a job that can be rushed, take your time, it took me 2 1/2 hours, cleaning as I went.
Thanks
Post #563824 6th Aug 2020 10:13pm
neilly
DrRob wrote:
Shiny Thumbs Up
Updated with info above, it seems we have the same RR.I do like the Blue when the sun shines on it.
Thanks
Neil
Post #563825 6th Aug 2020 10:21pm
DrRob
Great write up for future (Stan - maybe in Wiki ?)
Mine's Buckingham Blue Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #563842 7th Aug 2020 9:54am
Page 2 of 3 <123>
