Home > Maintenance & Mods (L322) > Viscous fan removal TD6
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
Quick question.
I have the correct spanner size 36mm and a long bar to hit it to shock the nut off.
It undoes in a clockwise direction yes? ie Left hand thread.
Im hitting this thing and its not budging. Big Cry
Post #563786 6th Aug 2020 4:41pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
If it's the same as the BMW 4.4 V8 , if you are relying on the belt tension to stop the pulley moving , it will likely slip. You need a second bar to hold the pulley in place.
Post #563787 6th Aug 2020 4:48pm
Snowy90 L322
Should have said its a td6 but your right the pully moved slowly, and i have heard that you can shock the nut loose
Post #563788 6th Aug 2020 4:50pm
BMG
Same thing happened with mine, spent ages trying to shock it hoping the belt would hold it just enough. Had to buy a cheap 2 bar kit from eBay to hold the pulley. If you have a bit of flat bar and and drill a couple of holes you can achieve the same thing.
Post #563792 6th Aug 2020 5:18pm
Snowy90 L322
Makes sense, I've stopped for the day until another fan spanner arrives tomorrow. Beer o clock now!
Out of interest what are the couple of holes for? is it not just to hold the inner nut from moving or is there an easier location to stop it moving?
Thanks for your help
Chris
Post #563794 6th Aug 2020 5:32pm
You really need to buy another thin spanner that goes onto a "nut" behind the viscous pulley with the arm resting on the top of the crankshaft vibration damper. One tap will shift it then.
If you need to know which spanner you need let me know and I will try and find the details. Thumbs Up
Post #563795 6th Aug 2020 5:33pm
Snowy90 L322
Thanks be good to know of the correct tool.
I have another 36mm spanner coming tomorrow and may get the welder out to fab something up.
As I'm driving myself mad it is clockwise to undo a left handed thread! lol stupid i know but i always find myself wondering if I'm tightening it!
Post #563797 6th Aug 2020 5:37pm
BMG
Chris
Basically a flat bit of bar with two holes. They slot over two of the four bolts on the pulley and stop it slipping as you use the 32mm spanner on the viscous nut.
Post #563798 6th Aug 2020 5:39pm
This is the one I bought to lock the shaft, worked really well. eBay item...... eBay Item No. 333434654711 Thumbs Up
Clockwise to undo. Very Happy
Post #563799 6th Aug 2020 5:39pm
Snowy90 L322
Chris
He makes that look easy! Thanks very helpful
Post #563800 6th Aug 2020 5:43pm
Snowy90 L322
Thanks
Post #563801 6th Aug 2020 5:45pm
Can I just say you don't need to disconnect any water hoses on the TD 6 to undo the viscous fan.
If you lock the spanner above onto the shaft nut and move it round to rest on the vibration damper then put your viscous fan spanner on at about the 10 past two position.
To then hit the end of the spanner you then need a bit of pipe or wood about 400mm long.
Hold the pipe or wood vertically one end on the end of the fan spanner and hit the top end of the pipe/wood with a decent sized hammer.
I suggest then undoing each of the clips holding the fan cowl in place, spin the viscous fan off the shaft and carefully remove the fan and cowl in one go.
Post #563802 6th Aug 2020 5:56pm
Snowy90 L322
Thanks Nice day! Good tips, i have the spanners now but its 30 degrees in my garage and i isn't dicking about with-it today lol. Im hot just thinking about it.
Will update in the week when its raining i believe!
Post #563924 8th Aug 2020 12:01pm
Note: TD6 only - cool running engine!
And once you have removed it, consider not putting it back on. You don't need it, engine/cooling will be fine without it. Many owners have done this, I ran for four years without it. Great for access to the bits at the front of the engine. .
Post #563926 8th Aug 2020 12:18pm
Snowy90 L322
Thanks Joe, May well try that.
Post #563927 8th Aug 2020 12:22pm
