Home > Technical (L405) > Fitting a dash cam using passenger compartment fuse box
FFRR64Royal
United Kingdom 2015 Range Rover Vogue SE SDV8 Firenze Red
Hi guys,
I want to install a dash cam into my car, can anyone recommend a ‘live on ignition’ fuse to use so I can hardwire the system in place. I do not like having loads of wires over the dashboard I would have by simply using the 12v socket.
Many thanks,
Neil
Post #563940 8th Aug 2020 2:46pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Hi Neil
Good idea. I fitted mine recently but it depends on what year your car is.
It might be an idea to add the details to your profile then members can advise as the fuses aren’t the same for all model years.
Chris 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #563941 8th Aug 2020 3:07pm
DrRob
Did a quick search for you using the Search button Thumbs Up
Any good?
https://www.fullfatrr.com/forum/topic48630.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #563944 8th Aug 2020 3:26pm
FFRR64Royal
Hi Chris,
Fairly new to the forum and only picked the FFRR up on Friday....updated my profile just now Thumbs Up
Post #563957 8th Aug 2020 4:07pm
FFRR64Royal
Dr Rob....brilliant and just the job.
Does anyone know if the GPS issue has been resolved? I too have a toll tag so would appreciate advice on best placement Very Happy
Post #563961 8th Aug 2020 4:15pm
chris_read
Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #563971 8th Aug 2020 5:39pm
Mine works fine here -
Post #563978 8th Aug 2020 6:56pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Mine too
Post #563980 8th Aug 2020 7:35pm
Phil.
I have my toll tag above the dashcam behind the black dots On the windscreen and it works fine. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #564003 9th Aug 2020 10:37am
FFRR64Royal
Any good?
All fitted as per the link....thank you DrRob Thumbs Up
Post #564482 13th Aug 2020 3:30pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Where would people suggest putting the battery for the Dash Cam? SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #564506 13th Aug 2020 6:41pm
most dashcams power from the cars 12v supply be it from the glove box fuse board or plugged into a power socket... ... - .- -.
Post #564517 13th Aug 2020 7:30pm
luxmoggy
I have answered my own question...
I will put it next the to fuse box in the rear of the car. There are a couple of good empty fuses to piggyback off.
From dash cam down the passenger side of the car. I have A pillar, door rubber, b pillar, door rubber and then down the c pillar...
For the rear camera I have... Tail gate panel, rear spoiler (you feed down into tail gate ),
Into car by rear spoiler, headliner (dont know if I need to do that, d pillar and then follow the power cable to the front of the car...
To know how to remove these panel can I look it up in Topix or is it easy to do? SDV8 AB MY 2020
Post #564519 13th Aug 2020 7:39pm
FFRR64Royal
luxmoggy
Try this link from DrRob...
I have just fitted mine using the information from the link and works perfectly
Post #564525 13th Aug 2020 8:23pm
