![]() | Home > Maintenance & Mods (L322) > Viscous fan removal TD6 |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
I’ve run mine for 2 years now without any problems also had a problem with the temp gauge not reaching 12 o’clock position, thought was egr thermostat. Replaced it twice thinking one was dodgy, turned out the main thermostat was failing. Changed it out all running good, made easier having the fan removed. 2004 Autobiography TD6 Java Black |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
WOW so with the heat showing no signs of easing i cracked on with the Fan removal and alternator replacement!
Your not wrong!
V8Simon Member Since: 18 Dec 2019 Location: North Wales Posts: 20 ![]() ![]() ![]() |
Just as an aside to this, my viscous fan has been 'sticking' recently and its sounded like a jet taking off every time I pull away and with the windows down quite loud. We've been away towing the caravan so not gone above 60mph for a few weeks now. I was facing replacing the viscous unit but did a run out last week of 20+ miles on duel carriageway. This seems to have freed up the viscous unit and doesn't engage from startup or running around.
