Home > Maintenance & Mods (L322) > Brake pad warning light. Cutting back wiring .
lee37Vernon
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi.
I've turned off the pad warning bong with my iid tool but am still left with the exclamation mark on the dashboard. Somewhere on the car is a wiring fault and I want to just cut out the pad warning loom, I always check my brakes and the car will be never be sold so no safety issues (is a 2003 Vogue by the way )
I thought I'd chased the earth fault down inside the osr door wheel arch pad but alas no.
Does anyone know where on the car and what colour wires I can loop together as close to the dash end as possible??
Thanks 👍 2003 4.4 Adriatic Blue FF
Post #564555 14th Aug 2020 10:26am
lee37Vernon
No one..?😭 2003 4.4 Adriatic Blue FF
Post #564601 14th Aug 2020 7:19pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
On my D3 if you cut the wires at the brake pad warning sensor and join the two ends together, it stops the pad sensor warning light. The pad wear sensors are cheap to replace.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #564622 15th Aug 2020 7:22am
lee37Vernon
Thanks Ivan.
I did that originally with no success, I believe there's a break in the wiring somewhere further info the car. I want to remove the wiring as far back towards the binnacle as possible and then join those two/ four end together.
I don't have a wiring manual that's why I'm hoping someone else had done this already.. looking to id the offending wires somewhere accessible near the dash. 2003 4.4 Adriatic Blue FF
Post #564637 15th Aug 2020 9:34am
GraemeS
Australia
According to the L322 wiring diagrams in the Wiki, 2 wires connect to the instrument pack in connector C0234 at pins 4 (yellow) and 20 (yellow with brown stripe). The 2nd wire from each connector are linked to provide the path. Joining pins 4 and 20 would short the path to indicate that both pad wear sensors are intact.
Post #564639 15th Aug 2020 10:28am
lee37Vernon
Good man..
I'll take a look, thanks 2003 4.4 Adriatic Blue FF
Post #564655 15th Aug 2020 1:19pm
