Home > Technical (L322) > L322 2012 Clunking sound |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Could be that. Get under there and have a look.
22nd Aug 2020 1:03pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
prop shaft issues are usually more pronounced under the greatest torsional load that the prop is under which is consistent with pulling way.
22nd Aug 2020 9:04pm |
Mousey Member Since: 22 Mar 2020 Location: Leicestershire Posts: 20 |
Got underneath yesterday, center bearing shot, as I have access to a ramp I'm going to hopefully sort it later. Is it a big no no to re-use the torx bolts? |
25th Aug 2020 10:24am |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Did you take the exhaust off to check it? 1995 4.6 v8, green/tan (long gone)
25th Aug 2020 11:46am |
No, Did a slight "mod" to the heat shield and am hoping to extract the shaft rearwards over the ex. pipes. Just need to get a torx socket first. |
25th Aug 2020 12:48pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
This is timely, mine developed a similar clunk yesterday, it’s definitely not connected to the steering, shocks or brakes but sounds like something underneath is knocking as the body moves. I did think it sounded like a prop shaft bearing but on wiggling and levering everything underneath I couldn’t detect anything that looked like it was making the noise.
26th Aug 2020 8:27pm |
Can only speak on mine, TDV8, where the 2 exhaust pipes come together there is a space that you can get your hand through to reach the front half of the rear propshaft, if it's in neutral the lift in the propshaft is obvious.
27th Aug 2020 10:38am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 389 |
I've found on the L322's that clunks when setting off are often from worn rear hub knuckle joints.
28th Aug 2020 11:20am |
Mine was deff. center bearing, sounded like tapping with a rubber mallet! All changed and sorted now. |
28th Aug 2020 12:09pm |
Great news Mousey Appreciate you'd already had yours in the air and diagnosed
28th Aug 2020 12:30pm |
Thanks for the advice all, I’ve been away so not managed to get under it, but will do so today. If I need to replace the bearing, would you advise replacing the prop shaft as well, or just reuse the one I have?
29th Aug 2020 10:23am |
Sorry, another question.
29th Aug 2020 10:47am |
I ran mine for 2000 miles plus, the noise didn't get any worse until I ran through some heavy rain.
29th Aug 2020 11:02am |
Cheers. I think last week may have been the first time it had ever been off road and through some proper ruts, the noise only started on the way home from that. I’m thinking that may have contributed to the demise of the bearing.
29th Aug 2020 3:34pm |
