![]() | Home > Technical (L405) > Airbag Light with B1408 Code |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2715 ![]() ![]() ![]() |
Very common, will be a break in the b pillar wiring or an issue with the connector under the passenger seat. If you search on here you will find info.. |
yelnats69 Member Since: 21 Dec 2019 Location: Dymchurch Posts: 35 ![]() ![]() ![]() |
Mr Tee
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Does your diagnostic machine do live readings? If so you can go through each airbag individual and see if any of the ohm’s readings are wildly different for one sensor, if so that’s likely to be your cause. Turned out to the the earth wire on the steering wheel airbag on mine, was a dead easy fix once located. This was also intermittent. |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
Hi
