Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 14 of 27 <123 ... 131415 ... 252627>
michaelpalmer7
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Yes I sent them pics of the incumbent cell with dimensions and they confirmed it is compatible.
I can’t see any visual damage on mine but clearly the system is doing the fault check then stopping so I think there must be an issue with it.
I’m just doing the drivers side for the moment and if it works will do the same on the other side. 2007 Range Rover L322 TDV8 Vogue SE (Rimini Red)
Post #566018 31st Aug 2020 9:21pm
DrRob
Great work 👍
Need to look at mine sometime... Thumbs Up Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #566021 31st Aug 2020 9:59pm
tinribs
2010 Range Rover Vogue SE TDV8 Galway Green
Any updates yet Michael?
I hadn't realised how big this thread had become! Embarassed
Post #566824 10th Sep 2020 10:26pm
michaelpalmer7
Nothing yet.
Shipping is quite long on the peltier cell.
It’s cleared customs in Ukraine by the looks of it.
As soon as it arrives will give it a go and post my findings. 2007 Range Rover L322 TDV8 Vogue SE (Rimini Red)
Post #566826 10th Sep 2020 10:34pm
Fat Lad
As a fellow 'cooling only' FFRR owner I am interested in how that replacement peltier cell works out for you too Michael. I'll be stripping my seats in the near future but I have a list of issues of which this is not a priority yet!
Good luck and fingers crossed. 1996 Disco 1 3.9 V8 on gas (Sadly Sold)
1996 Disco 1 300 TDI S (Thankfully Sold)
2004 Disco 2 TD5 ES (Sadly Sold)
2005 Disco 3 TDV6 HSE (Thankfully Sold)
2011 RR Vogue SE TDV8
Post #567038 14th Sep 2020 5:18pm
michaelpalmer7
So I’m afraid it’s bad news!
The item arrived and despite me sending the seller part numbers as well as all the dimensions of the faulty peltier cell to confirm it was in fact slightly too wide!
Given that I didn’t really have anything to lose I pinched it up slightly which did cause some of the end fins to touch and thought I’d try it anyway as modifying the housing to fit the bigger unit didn’t look like a viable option.
Plugged it in loosely and tested it and same issue as before, on cooling it fires up, change it to heating, nothing and the cell isn’t warming up then cooling won’t work either.
I don’t know enough about the make up of these things to work out if my pinching of the fins caused it or something else but the connections were good, soldered and heat shrunk and I made sure I got the 2 green wires the same way round as on the original.
Hopefully I should get back what i paid for this as it wasn’t as described however unless anyone has any other ideas I think I will be phoning LR Parts department Very Happy 2007 Range Rover L322 TDV8 Vogue SE (Rimini Red)
Post #567310 17th Sep 2020 3:21pm
michaelpalmer7
On a separate note I was just going through the wiring diagrams for the seats and the section on seats only seems to cover the standard ones with traditional elements.
https://drive.google.com/file/d/15VOpvPF6o...p=drivesdk
If anyone has come across a wiring diagram covering these please share as it would be interesting to check the connector pins to double check that it is the motor at fault on mine and not something else. 2007 Range Rover L322 TDV8 Vogue SE (Rimini Red)
Post #567311 17th Sep 2020 3:35pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Just ordered a lower seat climat assy. for US 49.99. Smile https://www.ebay.ch/itm/09-11-Jaguar-XF-Fr...2749.l2649
Only want to use the peltier, keep my fingers crossed to be able and have a fix on this... winter is coming Whistle
Post #569162 7th Oct 2020 8:21pm
t5pete
I too have the cooling only for the driver seat, the passenger works fine and the codes for the drivers are right seat back and right seat.
Post #569170 7th Oct 2020 9:09pm
3.6RR
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Did this work for you?
Post #570354 19th Oct 2020 9:37pm
Fox889
Am I correct in thinking, that there's 'two' heater units per seat? One at the back & one under the base?
My 2012 Westminster has no heat at all on the drivers seat, the fan runs for 30 secs then quits.
Before I get the local Indy involved I need to know the extent of what could be required to fix this.
I was under the impression, the one unit on the back seat fed the back cover & the seat base?
Be interested to hear what you folks have to say. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #570632 22nd Oct 2020 11:17am
rjff
There should be back and base units in your front seats assuming they have base and back heating and/or cooling.
Look in the Wiki for:
2010-2012 Workshop Manual\Auto Transmission and transaxle\Body and paint\Seats\Seats Gen and Testing
and you'll find some info on locations and there are threads on here about maintaining and opening them up. So far it apears no repair is available for the peltier part alone alhough if Ansi's try works there'll be a flood of orders to the supplier. Smile Cheers
Richard
Gap IIDBT
Post #570668 22nd Oct 2020 5:08pm
Ansi
Don't know yet. The unit arrived on Thuesday, will work on it on Saturday.
If I compare the look and the numbers on the Jag unit with pictures of the RR unit I may be able to swap the whole heating assembly. Thumbs Up
Post #570678 22nd Oct 2020 6:57pm
michaelpalmer7
The Jag units certainly seem easier and cheaper to come by so if someone manages to get one of those working then great.
I would be reluctant to fit a second hand one though as it could go again at any point but maybe the jag units are cheaper new from JLR also? 2007 Range Rover L322 TDV8 Vogue SE (Rimini Red)
Post #570711 23rd Oct 2020 9:01am
Ansi
So I took out the seat today and changed the Peltier-Part.
If I would have known that the Jaguar and the LR lower heating assembly are exactly the same then I would have looked out for a driver side unit (LHD). But nevertheless it was an easy job, taking the seat out and the cushion off was the hardest part of it.
I changed the Peltier by taking the 4 Pins one by one out of the plug and the “new” ones in. One by one to be sure that the 2 green wires are back in same position.
The entire job was done in about 45 minutes!
Post #570804 24th Oct 2020 12:12pm
