![]() | Home > Maintenance & Mods (L405) > Engine Oil Level - Not Available [4.4 SDV8] |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
I have had mine fail twice and spent around $ 4500 dollars .
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
Could grass cutting wire be used? Being yellow or red, maybe it would be easier to read, also to mark a level on it... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
I would imagine it would. If it was a thicker one. There is nothing that can't be fixed with a hammer😜😜
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409 ![]() ![]() ![]() |
I've not tried strimmer wire, and will give it a go.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1414 ![]() ![]() |
Jlr should sack the 'engineer' who came up with this idea and the person who gave it the go ahead.
Update:
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 301 ![]() ![]() ![]() |
My new (to me) 2013 SDV8 is going in to the garage shortly to have this fixed. Thankfully it's still under warranty. However, I would be interested in your "dipstick" for future use as I would not like to be picking up the bill for this.
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
Would this also work on the L322 4.4 TDV8? 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3882 ![]() ![]() ![]() |
TJRL,
Remove it when not in use.
Zebadee, if you want to make me one and ill check all the 405's/322's that come through the workshop? Would that help? |
Craig - that would be brilliant. Thanks.
Chris thegasman Member Since: 01 Oct 2021 Location: Midlands Posts: 2 ![]() ![]() ![]() |
Did this the other day with base guitar wire as advised works fine and as I guide we found that the level of oil when full was almost the same as the width side to side of the air box so an easy visual check if you haven’t got a tape measure
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 159 ![]() ![]() ![]() |
How would one use this checking method on an L322. ? where for instance is the 'entry tube' to shove the wire down ?
