![]() | Home > Technical (L322) > Interesting find re suspension last night |
130 for the BMW engine and 125 for the Jag engine.
Did he do it for free? ![]() |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
yes - literally a few minutes and at the same time altered the gearbox 'change' points - so that in overdrive it maximised economy whilst without overdrive it maximised performance! sorry the hark on but this is a cheaper car four years older than my FFRR - so many options available - many user selectable which was why i got a little heated about dealers charging to activate certain options ![]() i'll speak to him later this afternoon as he needs to fit the new Edelbrock front shock bushes i've just received from the USA - see what he can do on a FFRR hardly likely to be rocket science as its made in the UK ![]() |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Is it possible to reduce the 100mph threshold? It would be useful when towing to have it come in at m/way speeds. Ian |
Doesnt come in at all whilst towing regardless of speed as the suspension gets locked into standard height. Otherwise it would change the handling of the car/trailer if the height of the tow ball changed. ![]() |
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 ![]() ![]() ![]() |
Firmly locked into the ECU I am afraid. Can be removed though but via a flashing of the ECU, rather than changing an adaptation channel. Used to have: 2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped Now have: 2008 SSRR 3.6 TDV8 - HSE and plenty of toys |
Good man! ![]() ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6824 ![]() ![]() ![]() |
Does anyone have any thoughts/experiences of these places that offer to lower the heights of the various levels? It seems like a simple case of moving all the levels down by whatever value is desired? Got - 2017 SDV8 Autobiography in Loire Blue
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
you mean the £130 jobs advertised on pistoheads? not my cup of tea but ok if you want that kind of thing..
That sounds interesting! Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
found a link..
Cheers, but it only seems to be available for 2003-05 cars? ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
might be worth emailing him to see if it'll do yours... ... - .- -.
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 ![]() ![]() ![]() |
I lowered my tdv8 by 30mm handles so much better
