Home > Technical (L322) > Interesting find re suspension last night |
130 for the BMW engine and 125 for the Jag engine.
25th Mar 2011 1:27pm |
Did he do it for free? |
25th Mar 2011 2:07pm |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
yes - literally a few minutes and at the same time altered the gearbox 'change' points - so that in overdrive it maximised economy whilst without overdrive it maximised performance! sorry the hark on but this is a cheaper car four years older than my FFRR - so many options available - many user selectable which was why i got a little heated about dealers charging to activate certain options i'll speak to him later this afternoon as he needs to fit the new Edelbrock front shock bushes i've just received from the USA - see what he can do on a FFRR hardly likely to be rocket science as its made in the UK |
25th Mar 2011 2:10pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Is it possible to reduce the 100mph threshold? It would be useful when towing to have it come in at m/way speeds. Ian |
25th Mar 2011 3:21pm |
Doesnt come in at all whilst towing regardless of speed as the suspension gets locked into standard height. Otherwise it would change the handling of the car/trailer if the height of the tow ball changed. |
25th Mar 2011 3:23pm |
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 |
Firmly locked into the ECU I am afraid. Can be removed though but via a flashing of the ECU, rather than changing an adaptation channel. Used to have: 2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped Now have: 2008 SSRR 3.6 TDV8 - HSE and plenty of toys |
25th Mar 2011 4:11pm |
Good man! |
25th Mar 2011 4:24pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Does anyone have any thoughts/experiences of these places that offer to lower the heights of the various levels? It seems like a simple case of moving all the levels down by whatever value is desired? Got - 2017 SDV8 Autobiography in Loire Blue
2nd Apr 2011 4:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
you mean the £130 jobs advertised on pistoheads? not my cup of tea but ok if you want that kind of thing..
2nd Apr 2011 4:18pm |
That sounds interesting! Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
2nd Apr 2011 4:20pm |
found a link..
2nd Apr 2011 4:26pm |
Cheers, but it only seems to be available for 2003-05 cars? Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
2nd Apr 2011 4:30pm |
might be worth emailing him to see if it'll do yours... ... - .- -.
2nd Apr 2011 4:47pm |
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 |
I lowered my tdv8 by 30mm handles so much better
3rd Apr 2011 8:59pm |
