Home > Technical (L405) > What’s making the whooshing sound?
Page 2 of 5 <12345>
LT
Thanks Thumbs Up
All pulleys and belts have been changed.
The climate control is switched to off. Mainly so as to hear the sound clearer. It’s worth checking again with climate on and off though.
Post #566690 9th Sep 2020 8:29am
LT
I agree that it’s a case of “parts darts”. However, two “master technicians” from JLR have inspected the vehicle.
It’s costing them a lot of money. Not least because they gave me a D5 SDV6 HSE Luxury in Feb. with 500 miles on the clock. It’s now got over 13k miles on it.
Post #566691 9th Sep 2020 8:34am
D3Jon
Crikey, that's quite pronounced. At least they're looking after you with the loaner, which is good to hear Smile
My first thoughts would be a viscous fan which has been mentioned earlier in this thread (if that's what's fitted to your car). Failing that an obstruction in the air box or inlet pipework? Surely the LR techs would have checked for that already?
Hope you get this resolved.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #566709 9th Sep 2020 10:31am
LT
Thanks. Thumbs Up
I think I’m right in saying that’s there’s no viscous coupling on the SDV8. Happy to be corrected though.
It’s a slight comfort that it’s not unique to my vehicle.
Post #566711 9th Sep 2020 10:49am
chugga90
A study of eBay shows electric fan pack, so that eliminates viscous fan theory!
So definitely not that!
Post #566741 9th Sep 2020 5:45pm
LT
My gut feeling is that it’s something very minor, but not on the list of items replaced, doesn’t show up with pressure and smoke testing and obviously doesn’t trigger a fault.
The oil pump is being changed tomorrow. Fingers crossed but I’m sceptical of that being the cause.
Post #566744 9th Sep 2020 6:36pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Not sure how I missed this thread but mine is doing something very similiar having just come back from its third dealer visit this year (so far been off the road for 12 weeks) to fix a coolant leak and a number of other issues.
On its last visit they replaced the Oil cooler heat exchanger, the EGR cooler, the EGR and one of the turbos as they spotted its been leaking and when I picked it up it sounded a lot noisier then before especially in idle or low revs. I'll go back out in it shortly and see if I can detect the specific whoosing noise that yours has LT
Between 1000 and 1500 revs there is a noise resonance and minor vibration through the cabin and steering wheel and the high pressure fuel pump is very rattly (with a mechanics stethoscope on it at idle it sounds like its about to implode) - and you can hear a significant metal rattle as you come off the throttle as you approach a junction which I am fairly sure is the fuel pump again. However I'm not completely convinced that the issue is solely the fuel pump and your experiences suggest the same - it sounds to me like something in the air intake or turbo system isn't completely tight or even just something as small as a loose heat shield. Given that apparently the EGR and the oil coolers are quiet a significant engine strip down job I suspect something just hasn't been put back right but my problems are definately a combination of the fuel pump and something else.
I did find two air intake hoses which were loose when it came back and nipped those up - seemed to make a small change at the time but not so sure now. Its back in at the end of the month so will keep you informed too. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #566783 10th Sep 2020 2:37pm
LT
Thanks for your reply. The plot thickens!
Post #566784 10th Sep 2020 2:52pm
Took a video of mine today but haven’t figured how to use you tube yet.....
Basically exactly the same noise which occurs between 1050 and then is definitely less noticeable by 1150 rpm. There is nothing that can't be fixed with a hammer😜😜
Post #567067 14th Sep 2020 9:23pm
CUE99T
jesus thats noisey!!
Is it being amplified via the speakers as white noise or is it heard when you open the bonnet? all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #567203 16th Sep 2020 12:55am
LT
Yes, identical noise but kicks in at slightly lower rpm.
Post #567236 16th Sep 2020 1:28pm
LT
UPDATE:
Oil Pump has been changed and unsurprisingly it’s made no difference.
So that’s basically all the ancillary parts replaced.
Post #567237 16th Sep 2020 1:29pm
Sounds Possibly turbo related to me.
I’m assuming they have looked at yours and ruled this out..?
I still havent managed to ace a snoop round to see if I can narrow it down though. There is nothing that can't be fixed with a hammer😜😜
Post #567278 16th Sep 2020 9:05pm
LT
High pressure fuel pump
ACE Pump
Water pump
Alternator
Both turbos
Oil pump
A smoke and pressure test has been carried out, twice!
Whilst both front and rear turbos have been replaced, that’s not to say that it’s not turbo related but it’s not any part of the turbo set up that is monitored by a sensor.
Post #567282 16th Sep 2020 10:19pm
chugga90
They have special air intake arrangement.
Could it be within that?
Would they be prepared to disconnect the integrated air intake and connect a temporary solution to the air filter box and try?
Must commend them on their persistence, not a quality usually found in JLR dealers.
Post #567287 17th Sep 2020 6:48am
Page 2 of 5 <12345>
