Home > Wheels & Tyres > L322 Spacers
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Don’t do spacers I’m pretty sure your insurance company won’t cover it on such a heavy car. I would suggest if you want an aggressive stance buy wheels with a different offset.
Either option you need to declare to insurance otherwise your not covered.
Post #566786 10th Sep 2020 3:13pm
LT
Yes, spacers would be considered a modification and need to be declared. Thumbs Up
Post #566788 10th Sep 2020 3:33pm
mjdronfield
Just more of a general query..... Doesn’t adding spacers put more load on the wheel bearings due to extra width/leverage or have things moved on from the days of the Ford Cortina?
Just thinking of the physics rather than anything else specific to RR. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #566789 10th Sep 2020 3:33pm
Iain24ace
United Kingdom 2007 Range Rover Vogue SE TDV8 Barolo Black
You can achieve the same look without spacers by changing the wheels to RRS 20 inch Stormers as they are an inch wider I believe and fit straight on. The tyre size needs to be increased in profile from 275/40/20 to 275/45/20 and they then have the same rolling radius as the original 255/50/20.
Post #566791 10th Sep 2020 3:55pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Yes, it does increase the load on the wheel bearings - exactly the same for increased offset wheels that achieve the same visual effect. End result is reduced bearing life, but probably no big deal compared to the already woeful life of the standard suspension ball joints & rubber bushes. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #566799 10th Sep 2020 5:31pm
kevinp
Hi Paul, I agree with you one hundred percent about the life of the suspension joints and bushes. My thoughts are that they can't be made too stiff [bushes] because of the large articulation they can go through when off road. Far more movement than a conventional car even though most of our cars never see that movement in normal use. I was amazed how much the suspension 'hung' the first time I jacked my car up to remove a wheel. I had to get a taller jack. Lol.
Post #566972 13th Sep 2020 8:15am
