Home > Maintenance & Mods (L322) > Spongy Brakes - SORTED |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Kbald, I assume you mean brake fluid leaking from the master cylinder? If so, you are not using the correct rubber seal in the cap. It happened to me when I used a thicker seal and it wasn't seating properly on the reservoir.
10th Sep 2020 5:51am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Brilliant thanks for the tips. I had heard great things about the easibleed so got one but the huge leak at the cap on the cylinder out me off but will try again. I'd taken the and pump off when I replaced my manifold so expected if to be going crazy from the first moment. Maybe just need to follow the process through fully.
10th Sep 2020 6:39am |
I have bled brakes before but this kit is amazing. I didnt take the rear wheels off as there is plenty clearance.
10th Sep 2020 7:28am |
Thanks for the advice I will give it a try Current 2007 TDV8 Vogue Buckingham Blue |
13th Sep 2020 8:46pm |
