![]() | Home > Technical (L322) > Hot smell after drive 4.4 tdv8 |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
Hot, as in, "oily hot" then one would suspect the infamous oil cooler leak & associated 'O' rings etc.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
I'm with Fox on the hot and oily smell.
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Doesn’t smell like oil burning and it’s not used a drop in 4K miles. Anyone know if there is a gearbox temp monitor on IID tool? 1995 4.6 v8, green/tan (long gone)
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
I'm sure there is - it's part of the fill-level procedure (at least on the 3.6). 2016 Skoda Octavia VRS Estate
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3876 ![]() ![]() ![]() |
I would put the bonnet lid in the vertical service position.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Ditto on what Mike said... |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1345 ![]() ![]() ![]() |
I used to get a hot antifreeze/coolant smell from mine. I had a lot of trouble bleeding all the air out, but I've also put on a new expansion tank cap and it doesn't smell anymore. Might be worth checking coolant level? |
Cheers all for the suggestions. Will check down the back tomorrow and the coolant level 1995 4.6 v8, green/tan (long gone)
Here are pictures, can’t see anything wet. There is a faint coolant smell around the expansion tank but only when you’re right on top of it. No dampness anywhere. May need to get underneath
Does it use coolant? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Nope 1995 4.6 v8, green/tan (long gone)
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
As Kevin has mentioned the expansion cap curing his "smell" it might be worth getting a new one if not too expensive, it may be that it's lost some of it's strength and is venting more than it should, hence the smell. 2011 TDV8 Vogue SE |
Dooh! |
Coops, i think you should take her for a run then check the temp of each wheel and see if one is getting hotter than the others? This could point to a sticking caliper as mentioned above...
