Home > Maintenance & Mods (L322) > Transmission sump plug
Tom Paine
Australia 2003 Range Rover HSE Td6 Bonatti Grey
I need a transmission sump plug for my 2004 diesel L322as the one in place is badly burred and I doubt if I'll get it back in. Part number, I think, is TYB500100. Island 4x4 haven't got any and LR direct tell me it's obsolete - cheeky sods.
Has anybody got one to spare? Or know an infallible source?
Post #567069 14th Sep 2020 9:28pm
stuart_2006
Is it the sump plug on the bottom or the filler plug on the side? For the TD6?
Advanced Factors seem to have the sump plug. [https://www.advancedfactors.co.uk/tyb500100-drain-plug-tyb000060-6404-p.asp]
For the filler plug, I had to get mine from Latvia. [https://www.ebay.co.uk/itm/Genuine-BMW-E46-E53-E83-Estate-SUV-Outer-Hexagon-Screw-Plug-OEM-24117507787/132471433040] Contrary to what the picture shows, this is the filler plug towards the front of the gearbox, with a hex head. This is the plug under the BMW part number.
Post #567082 15th Sep 2020 12:35am
p38arover
Australia
Re: Transmission sump plug
Take it to SuperCheap and see what will fit. That's what I did for the engine sump plug when the sump was stripped. I bought one with more thread as a temporary measure until I could drop the lower sump and drill, tap, and fit a HeliCoil.
Sump plugs aren't rocket science. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #567088 15th Sep 2020 4:45am
Tom Paine
P38, I begin to suspect you're right. Advanced factors and LRDirect have both sent my money back and Island 4x4 can't get any. It's wreckers or get an old sump and hang around Supercheap and Boltmasters.
I agree they're not quite rocket science, but I really don't want one dripping oil, or working loose.
Post #567095 15th Sep 2020 8:26am
p38arover
Australia
If it's not refitted, take with you to SuperCrap or Boltmaster. If you don't have any pitch gauges, the latter will tell you the size.
This is the type of sump plug I fitted to my engine while awaiting the helicoll kit. Notice the o-ring seal. It didn't leak. I got it at SuperCrap.
https://www.supercheapauto.com.au/search?q...lang=en_AU
BTW, I think your part no. is incorrect. What's your VIN? Less than 5A000001?
The drain plugs are:
TYB000060 - (PLUG - OIL DRAIN) [ VIN to 4A999999 ]
TYB500100 - (PLUG - OIL DRAIN) [ VIN FROM 5A000001 ] Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #567141 15th Sep 2020 12:56pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
If it's a TD6 then it's the GM5L40E transmission which is used on vareity of other vehicles abliet in slightly different configurations, e.g. 2WD M82 version on BMW E46 or E39 diesels or even some Holden Commodores over there.
https://en.wikipedia.org/wiki/GM_5L40-E_transmission
I know the filters change slightly between models but can't believe the sump plug is any different between them, it'll be a standard metric size (M16 or M18 no doubt).
Just have to think laterally, search for the gearbox itself and not what's fitted to as Land Rover didn't make the gearbox.
Post #567142 15th Sep 2020 1:05pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
find a near match nut and bolt. Weld nut to sump over hole and use the accompanying bolt ( with a washer of course )
Post #567187 15th Sep 2020 7:16pm
Tom Paine
Gentlemen, thanks for your thoughts. I was looking at wreckers and possibly buying the whole sump pan, but the idea of searching by box number hit the spot. I find that this box is fitted to BMW 3 and 5 series, and more to the point, to Holden Commodores 2004 to 2010.
I should be able to buy a Commodore plug in Woolworths.
Thanks again
Post #574255 27th Nov 2020 5:53am
