Home > In Car Electronics (L322) > Right Side Speakers Not Working
SomeLankyGuy
Hi!
Hoping for some advice again please
I have a 54 plate 4.4 Vogue, with the DSP system. I have been messing around with the car trying to remedy a few issues, haven't managed to solve anything, but I have developed a new problem!
All the speakers on the right hand side do not work. I had the door card off for a central locking issue, so I thought I forgot to reconnect them. Unfortunately it wasn't that simple! I then noticed the rear door speaker isn't working, either.
The dash centre speaker and subwoofer in the boot are working
Short of splashing £200 on a DSP amp that might not fix it, I'm not really sure what to do
Any ideas?
Cheers
Post #567182 15th Sep 2020 5:43pm
SomeLankyGuy
I did also wonder if it could be the BM54 unit, maybe/
Post #567185 15th Sep 2020 6:51pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Have you tried checking for DTCs/fault codes? Was doing that recently and cleared one relating to the speakers which seems to have resolved an issue with the lower passenger door speaker. If the amp had gone none of the speakers would work?
Try a battery disconnect/reset?
Post #567200 15th Sep 2020 11:34pm
Bloke
Also try this.
Post #567201 15th Sep 2020 11:36pm
SomeLankyGuy
Appreciate the reply mate!
No I've not tried a fault code scan, but I do have one at home so I'll give it a go and see what happens
And yeah, I tried a hard reset on the car earlier but didn't seem to do anything!
Cheers again
Olie
Post #567202 15th Sep 2020 11:37pm
Could well be a bad connection in the plugs / sockets on the top of the dsp, particularly the plug nearest the centre of the car.
I had similar problem and found it by wiggling the wiring harnesses above each plug to the extent I could switch the speakers on and off at will. I resolved it by simply cable tying the offending cable harness firmly in place and never had a property since.
Post #567206 16th Sep 2020 7:04am
