![]() | Home > In Car Electronics (L405) > New satnav update 2020/2021 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
coincidentally i have just updated my igo primo to the 2q 2020 maps.... ... - .- -.
kudus to Simon and his videos, they are very helpful... ... - .- -.
jamesey Member Since: 11 Jun 2019 Location: England Posts: 2 ![]() ![]() ![]() |
Just updated my 2015 sat nav with the latest 2020 maps...took a risk with a Spanish supplier..at £84 and all worked! New maps! Although had problems downloading the file over the internet, they sent a USB stick which worked. It takes about 2.5 hours but will pick up where left off so that you can update over a number of journeys. |
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
I've now been able to test the new maps - so far, so good. As highlighted on the Here site, lane suggestions are greatly improved. Previously these only seemed to appear on motorway guidance but now on multi-lane A roads. Only weird thing is a no through road near my house now appearing as the opposite (I wish it were so!). |
Tom_T Member Since: 22 Jun 2020 Location: Essex Posts: 44 ![]() ![]() ![]() |
I’ve had a problem with mine and hope some of you can offer some advice
I would certainly give it another try - it certainly takes as long as indicated! Then you can call LR if you get the same result. It important to remove the stick as soon as the update is complete, then switch off, lock the car and leave for at least 20 minutes. If it's worked, the system will have rebooted and the maps should appear. |
Tried it again and I get a message saying that the data on the USB is older than the data in the nav, so it won’t update.
