Home > Technical (L405) > suspension
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
suspension
So, something always happens when I am away with work and the car is at home with wife. L405 SDV8 suspension is cycling or wobbling side to side when the car is static. I instructed the wife to try raising and lowering the suspension manually and the dynamic response light came on. LR Assist are en route. Any ideas of causes?
Post #567846 23rd Sep 2020 4:56pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
I would guess a leak somewhere and low fluid?
Presume you have lowered, switched off, locked, restarted etc?
Post #567853 23rd Sep 2020 6:26pm
cupples8267
Update. AA came out, apparently its a fault with the rear Anti Roll Bar control valve. The bar is essentially kicking in and out. looks like it'll need to go into the dealer. The AA guy has left, apparently he pushes a button and that notifies the dealer.
Post #567855 23rd Sep 2020 6:33pm
cupples8267
Patrol found the following fault code/s:System : Chassis/steering - 7MH / Roll stability control 4.1U0001 - High-speed CAN bus. Error Message : Missing message.C1048 - Safety valve. Error Message : Component hanging open.Check for suspension fault, no lights on at test but vehicle rocking every so often, heck faults , shown above, erase faults and visually inspect rear active roll bar, nothing obvious, but vehicle still rocking with faults erased, have garage check over further.
Post #567857 23rd Sep 2020 6:54pm
qwerty
Be interesting to find out the resolution to this keep us posted. Thumbs Up
Post #567878 23rd Sep 2020 10:20pm
cupples8267
Thank you, I'm thinking the valve block from anecdotal evidence but I will post updates.
Post #567879 23rd Sep 2020 10:23pm
cupples8267
Update- the car went into MD who tried to replicate the fault. Due to AA clearing it no fault codes were present. The fault has so far not come back.
Post #569807 14th Oct 2020 6:43pm
qwerty
umm, not ideal and rather annoying for you. Does it now drive ok?
Post #569817 14th Oct 2020 8:08pm
cupples8267
Yes thanks, it drives well, no sign of that fault. Handbrake is now faulty but actuator being replaced tomorrow.
Post #569818 14th Oct 2020 8:09pm
