Home > Technical (L405) > suspension |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 54 |
I would guess a leak somewhere and low fluid?
23rd Sep 2020 6:26pm |
cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 62 |
Update. AA came out, apparently its a fault with the rear Anti Roll Bar control valve. The bar is essentially kicking in and out. looks like it'll need to go into the dealer. The AA guy has left, apparently he pushes a button and that notifies the dealer. |
23rd Sep 2020 6:33pm |
Patrol found the following fault code/s:System : Chassis/steering - 7MH / Roll stability control 4.1U0001 - High-speed CAN bus. Error Message : Missing message.C1048 - Safety valve. Error Message : Component hanging open.Check for suspension fault, no lights on at test but vehicle rocking every so often, heck faults , shown above, erase faults and visually inspect rear active roll bar, nothing obvious, but vehicle still rocking with faults erased, have garage check over further. |
23rd Sep 2020 6:54pm |
Be interesting to find out the resolution to this keep us posted. |
23rd Sep 2020 10:20pm |
Thank you, I'm thinking the valve block from anecdotal evidence but I will post updates. |
23rd Sep 2020 10:23pm |
Update- the car went into MD who tried to replicate the fault. Due to AA clearing it no fault codes were present. The fault has so far not come back. |
14th Oct 2020 6:43pm |
umm, not ideal and rather annoying for you. Does it now drive ok? |
14th Oct 2020 8:08pm |
Yes thanks, it drives well, no sign of that fault. Handbrake is now faulty but actuator being replaced tomorrow. |
14th Oct 2020 8:09pm |
