![]() | Home > Technical (L322) > 2011 Sc: Gearbox fault, hdc not available, adaptive dynamics |
orthopod Member Since: 02 Oct 2020 Location: Braselton, ga Posts: 6 ![]() ![]() ![]() |
I think it is acting like a neutral sensor switch, but may be mechatronic unit, but the tranny shifts perfectly as
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Maybe the gearbox shift cable is out of adjustment. Can the fault be triggered by moving the shift lever backwards or forwards a little? |
No..it requires a full shift |
There should also be fault codes stored for the adaptive dynamics and HDC faults. If your tool can't find them then you may need access to a LR-specific diagnostic tool.
Specific fault codes stored are:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
If it’s a shifter issue then do a bit of Lubrication on the shifter Bowden cable.
Kuret Member Since: 07 Feb 2024 Location: Ontario Posts: 10 ![]() ![]() ![]() |
Did you get this solved? Did you end up replacing the transmission? I have the same fault issue happening intermittently. |
I have the following codes.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
The Turbine/Input shaft speed sensor and the Park/Neutral switch are mounted on the same plastic component which is a separate part of the electronic module of the Mechatronic unit. The six connections I’ve labelled A to F in the photo are for the -ve, L1, L2, L3 & L4 and +ve connections for the Park/Neutral switch. F & G are the +ve & speed data terminals for the speed sensor. The positive feed F is shared by the two. I suspect this is where your fault lies.
Thanks for the tip Phil. I am due for a transmission filter and fluid swap so I will pull the valve body and mechatronics unit while I am in there.
I see you have a 2011 5.0 SC, so you have the 6HP28X transmission. The connection between the position switch/speed sensor assembly and the rest of the electronic module does not involve any wires. All the circuits between the ECU and the sensors are on metal bars which are spot welded together.
Thanks for all your support here.
