Home > Technical (L322) > TD6 STARTING ISSUE
mercs600
England 2002 Range Rover Vogue Td6 Java Black
TD6 STARTING ISSUE
Hi - I have an occassional problem in starting the vehicle in that the starter motor 'spins' the engine over for approx 2 seconds and then just makes a 'whirring' sound as it rotates !
Not sure of where to look - I thought starter solenoid but it initially 'throws' the starter into the ring gear so I don't think this is the problem.
Just wondering if anyone else has had something similar ?
Oh yes - sorry it's a '52 plate TD6. Neutral
Post #56828 26th Mar 2011 8:05pm
anything that sounds like its spinning and not engaging suggests that the unit is knackered, in this case the starter motor.. ... - .- -.
Post #56834 26th Mar 2011 8:39pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
May be worth getting down and dirty and checking all the earth cables. Also check the Positive is nice and tight and clean to the left of the battery where the postive to the starter can be disconnected. (Follow the positive and you will find it after about 10 inches or so. Thumbs Up
If that fails then it may be the starter needs to be replaced. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #56894 27th Mar 2011 2:11am
mercs600
Thanks for the replies. I'm going to check the connections today - but was also thinking down the lines of a new starter motor Sad Seen them on Ebay for about £200 - is this a good price ? Neutral
Post #56898 27th Mar 2011 7:49am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Sounds like the pinion on the starter motor is not engaging. This points to the solenoid on the starter not flicking the drive gear forward onto the flywheel. Could be loose conection, or gunged up solenoid.
Post #56911 27th Mar 2011 11:22am
ben2012
2005 Range Rover Vogue Td6 Buckingham Blue
I've just noticed exactly the same issue on my 2005 ffrr and was thinking it was linked to the starter motor, girlfriend noticed the other morning that it wouldn't start up first thing and then later that day tried it myself and it was doing exactly as u described, keep updated on how you go on, mine seems to be working ok at the mo, touch wood!!
Post #56992 27th Mar 2011 7:56pm
elpeede
H'mmm both TD6's... lets hope its not a post winter trend Neutral 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #56995 27th Mar 2011 7:59pm
ben2012
Any update on this yet? Mine seems to have been ok since! (touch wood!)
Post #57479 29th Mar 2011 11:41pm
mercs600
Yep - mines also been ok - so far ! Wink
Post #57715 31st Mar 2011 6:30am
That's it confirmed then, FFRR's are female and prone to mood swings Big Cry
Post #57731 31st Mar 2011 9:06am
mercs600
I've done a few long journeys recently (150 miles +) so maybe the battery voltage was a bit low ? Anyway - fingers crossed and we will see Wink
Post #58206 1st Apr 2011 10:12pm
Vogue
thats it, we get this on older tractors, usually happens in cold weather when the lube is thick / gunged up, usually if the motor is removed and a squirt of silicone lube sorts it - the pinion needs lube or it can stick
Post #58207 1st Apr 2011 10:26pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
me also but just the whurrring sound
Yep, i had this occasionally during a 'cold' spell - ignition back to 0 then try again and it starts. First thought were battery but was told (as a non technical, dirty diagnosis) to leave door open and see what happens to interior light - no change to brightness.
It was looked at when i was back in the UK and connections looked ok and since the warm weather no reoccurence (touch wood).
Post #58222 2nd Apr 2011 7:48am
