![]() | Home > Technical (L322) > TD6 STARTING ISSUE |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
anything that sounds like its spinning and not engaging suggests that the unit is knackered, in this case the starter motor.. ... - .- -.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
May be worth getting down and dirty and checking all the earth cables. Also check the Positive is nice and tight and clean to the left of the battery where the postive to the starter can be disconnected. (Follow the positive and you will find it after about 10 inches or so. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Thanks for the replies. I'm going to check the connections today - but was also thinking down the lines of a new starter motor |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Sounds like the pinion on the starter motor is not engaging. This points to the solenoid on the starter not flicking the drive gear forward onto the flywheel. Could be loose conection, or gunged up solenoid. |
ben2012 Member Since: 10 Jan 2011 Location: West Yorkshire Posts: 54 ![]() ![]() |
I've just noticed exactly the same issue on my 2005 ffrr and was thinking it was linked to the starter motor, girlfriend noticed the other morning that it wouldn't start up first thing and then later that day tried it myself and it was doing exactly as u described, keep updated on how you go on, mine seems to be working ok at the mo, touch wood!! |
H'mmm both TD6's... lets hope its not a post winter trend |
Any update on this yet? Mine seems to have been ok since! (touch wood!) |
Yep - mines also been ok - so far ! |
That's it confirmed then, FFRR's are female and prone to mood swings |
I've done a few long journeys recently (150 miles +) so maybe the battery voltage was a bit low ? Anyway - fingers crossed and we will see |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
thats it, we get this on older tractors, usually happens in cold weather when the lube is thick / gunged up, usually if the motor is removed and a squirt of silicone lube sorts it - the pinion needs lube or it can stick |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
Yep, i had this occasionally during a 'cold' spell - ignition back to 0 then try again and it starts. First thought were battery but was told (as a non technical, dirty diagnosis) to leave door open and see what happens to interior light - no change to brightness.
