Home > Maintenance & Mods (L322) > Fixed side steps
t5pete
Fixed side steps
I've just removed my side steps due to them being rotted, what is the general opinion on where to get replacments?
There's sets on ebay for as little at £150.00 and others on there ranging around £300.00.
Heres mine absolutely shocking quality
Thank you
Post #569498 11th Oct 2020 2:23pm
aftermarket ones wont be as good as OE but are acceptable...
the ebay steps do attract rust so i'd paint the underside with a few coats of hard wearing paint before fitting...
or, you could spend a bit more and go 'deployable' ... - .- -.
Post #569506 11th Oct 2020 4:28pm
t5pete
Afternoon Stan,
I'll take a punt at the ebay ones then its not a lot of money if they are still usable and look good.
Ide gladly pay the extra for deployable but honestly don't like the look of them I prefer the chunky fixed steps.
Post #569512 11th Oct 2020 5:00pm
darrenm
I bought a set from turborevs £130 and so far so good I fitted them in 2017
[img:323:699]
https://www.fullfatrr.com/gallery/albums/u...3.png[/img
Post #569513 11th Oct 2020 5:04pm
t5pete
That's good news Darren
Post #569520 11th Oct 2020 5:45pm
Range Rover L322
This is the post to read: "Are cheap side steps any good" .
I compared them in the post and I found the cheap ones are perfectly acceptable but I did give the undersides 2 more coats of paint.
https://www.fullfatrr.com/forum/topic56802.html
Post #569545 11th Oct 2020 8:51pm
t5pete
That's great i purchased these earlier on today so hopefully all will be fine.
https://maltings4x4store.co.uk/range-rover...ide-steps/
Post #569549 11th Oct 2020 9:15pm
Range Rover L322
Those ones you've ordered look perfect. Just paint the undersides. I used Hammerite just because I had some but next time I will get canned stonechip and do it even better. When the mounting brackets are off it's a good opportunity to clean the mud out of recesses at the front. There was a good pint of mud in both sides of mine. Good luck!
Post #569555 11th Oct 2020 10:07pm
t5pete
Thank you,
The plan is to remove the arch linings,sill covers and as much underside covers as possible to shot blast and then rust proofing including waxoiling the inner sills
Post #569559 11th Oct 2020 10:28pm
Range Rover L322
sounds like you're doing a great job - please photograph and post ! We love it!!
Post #569561 11th Oct 2020 10:47pm
Classic Matt
It's amazing that such new cars need such a level of work to keep them rot free. The side steps on mine were in similar condition and under them I have also found a few areas that the original underbody protection has chipped away in so will now be cleaning down and protecting them.
Post #569564 11th Oct 2020 11:00pm
t5pete
It is Matt, I don't mind the maintenance/ mechanical works but land rovers rust proofing is terrible we've got a few volvos some nearing 35yrs old and none have the same amount of rust a 9yr old land rover has.
Thankfully it will all be caught in time and correctly prepped and proofed meaning no further issues and should be done for life.
Heres one of the 240's this needed no welding once the original rust proofing had been removed
Post #569617 12th Oct 2020 1:15pm
Classic Matt
That's amazing! I really like the old Volvos, I'm yet to own one but have great memories of being a passenger in a few 240s when they were newer. Definitely a car on my ownership bucket list.
What will you use to prep/coat the underside of the Range Rover? I was reading up on different systems last night but a recommendation based on experience would be great. I have previously worked with bare metal but I'm conscious I can't guarantee removal of every spec of rust with this so want to use the right combination of products to account for that.
Matt.
Post #569620 12th Oct 2020 1:47pm
t5pete
I normally get back to bare metal then red oxide, seam sealer and stone chip after that normally go over with the car colour but for the range rover I'm not going that into detail
Plan of attack is
Get down to clean bare metal
Red oxide
Seam sealer
Stone chip
Wax oil external
Also inner sills wax oil.
I've done this method a fair few times and never had any issues.
This is the T5r I did about 6 years ago and still in good condition
Post #569625 12th Oct 2020 2:26pm
Classic Matt
That looks fantastic!
The plan of attack sounds good. I wish I had some indoor space for the job, but ramps on the drive will have to do. At least the car will provide shelter from the rain!
Post #569629 12th Oct 2020 3:19pm
