Home > Technical (L322) > FBH woes |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Whilst I note you are from the Grim North so this question may be superfluous , but was it cold enough for the FBH to fire?
28th Sep 2020 1:22pm |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 154 |
Hi, bish has a point there. If the outside temp is 16 degrees or higher it won't fire up to heat the interior. At that temp it will try and cool the car. I would check the FBH by doing it manually through the timed climate on the touch screen first to see what happens. |
28th Sep 2020 3:33pm |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 |
Cheers, AYE always cold up Norf. When I was trying to fire it, temp was 7 degrees. I know when engine is running and it’s less than 5 it starts. Not tried the dash settings, but will try tomorrow. I’ll charge the battery too just in case it was too low. |
28th Sep 2020 11:19pm |
Its been a while, other week when I tried to fire the FBH it started and stopped after 30 secs.
13th Oct 2020 7:43pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
Vehicle battery voltage too low, replace / check the vehicle battery. I proved it on my 322 by leaving the battery charger connected, FBH started and ran perfectly. The battery had no problem in starting the vehicle. Battery replaced and FBH ran as it should. BMW i3 Electric Car
14th Oct 2020 7:23am |
AJ,
14th Oct 2020 11:01pm |
Try leaving the temperature set high(ish), if you can connect a battery charger and lock the car. Now trigger the FBH when the car is cold and the outside air temp low. Under these conditions mine ran perfectly, ramped up after ignition and warmed the interior nicely. Repeating it the following day without the battery charger connected, the FBH started and shutdown within a couple of minutes. Having read on here about the battery voltage being critical and confirmed pretty much it was shutting down due to voltage, I replaced the battery and it resolved the issue. At no time had I had any starting problems with the battery even under the worst conditions just the FBH not running. It does seem that the shutdown of the systems radion and FBH are set to a relatively high battery voltage. BMW i3 Electric Car
15th Oct 2020 6:10am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
Check the FBH Aux pump is ok, classic tell tale sign it’s failed / failing is that the FBH runs fine with the engine running but shuts down quickly as a aux heater due to overheat caused by a lack of water flow. When the engine is running you have the main water pumps so it will happily run. Changed it twice on our 2007 TDV8. Get under the passenger side and confirm operation via its exhaust, the HVAC alone makes enough noise! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
15th Oct 2020 7:50am |
I’ll run it and check the exhaust of the FBH. It did run on its own for quite a while without engine running. |
15th Oct 2020 11:26pm |
I think TJH is referring to the electric water pump to circulate the coolant during FBH operation. If this isnt working the FBH only runs for a short time i.e. until the water is hot at the FBH. BMW i3 Electric Car
16th Oct 2020 6:22am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3646 |
As this thread will have got the attention of FBH experts maybe someone can help. I have tried to use mine for the first time since getting the car and from the fob the light is initially green then flashes green but it doesn't seem to heat. Is there something to check, do things need to be paired - its not a show stopper I get by with heated seat and steering wheel but it worked fine on my previous diesel RR (apart from flattening the battery if left on too long) and I miss it.
16th Oct 2020 5:32pm |
It does need to be paired, there is the process on here somewhere, it also needs to be the right key, mine was supplied with the wrong one.
16th Oct 2020 5:58pm |
Classic Matt Member Since: 05 Sep 2020 Location: West Sussex Posts: 72 |
This and other FBH threads make me nervous of trying mine for the first time! |
16th Oct 2020 9:09pm |
