![]() | Home > Technical (L405) > Front calliper pins |
| charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174
The pins exit by punching them in the direction center of the car , a huge force is required as they seize into the alloy body of the caliper . You may need to heat the caliper and / or freeze the pin . Putting new pins back needs just a small tap as the collet goes in . Plenty of copper grease !!!!! |
| jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 |
I got the pins out very easily.
LOL You are going in the direction of the center of the car to the outer side ? The cotter should just tap in . Have you got LR part No LR 016682 ? |
I hammered it in from inside towards outside. I did that part right.
The only other thing i can think of of is to ream the inner hole in the caliper to make sure its clean and free , maybe a rolled up wet and dry followed up with copper grease . |
jackcramerr : Did you sort this out ? what was the cure ? |
Hammered them. No other way. |
See these guys just slide them in and never hammer... I think they are wrong here...
| All times are GMT |
