Home > Technical (L405) > Front calliper pins
jackcramerr
Front calliper pins
Do the front calliper slide pins need to be hammered in? I saw in videos people just slide it but looking at the existing pins that are on the vehicle, it seems more protruding outwards.
Noticed on new pins there is a sort of tapered collar ring meant to be seated. Any ideas?
Post #569658 12th Oct 2020 8:29pm
charlie croker mk2
The pins exit by punching them in the direction center of the car , a huge force is required as they seize into the alloy body of the caliper . You may need to heat the caliper and / or freeze the pin . Putting new pins back needs just a small tap as the collet goes in . Plenty of copper grease !!!!!
Post #569661 12th Oct 2020 9:42pm
jackcramerr
I got the pins out very easily.
But putting new ones in is a pain. Small tap did not work and I spent a lot of time on it. Ruined the calliper paint work by sometimes missing to hit the punch tool. However, the two videos I saw online, none tells you to tap/hammer new ones in...
Post #569663 12th Oct 2020 10:27pm
charlie croker mk2
LOL You are going in the direction of the center of the car to the outer side ? The cotter should just tap in . Have you got LR part No LR 016682 ?
Post #569664 12th Oct 2020 10:33pm
jackcramerr
I hammered it in from inside towards outside. I did that part right.
The pins are identical to the ones I hammered out. Used one made by PAIGD.
Post #569666 12th Oct 2020 11:10pm
charlie croker mk2
The only other thing i can think of of is to ream the inner hole in the caliper to make sure its clean and free , maybe a rolled up wet and dry followed up with copper grease .
Post #569667 12th Oct 2020 11:14pm
charlie croker mk2
jackcramerr : Did you sort this out ? what was the cure ?
Post #570270 19th Oct 2020 12:04am
jackcramerr
Hammered them. No other way.
Post #570518 21st Oct 2020 4:38pm
jackcramerr
See these guys just slide them in and never hammer... I think they are wrong here...
Post #570519 21st Oct 2020 4:41pm
