Home > Wheels & Tyres > 275/45/20 tyres on SVD8 L405
FFRR64Royal
United Kingdom 2015 Range Rover Vogue SE SDV8 Firenze Red
Hi guys,
I am still on the hunt for an all season tyre to replace my current Michelin F1 M&S that came with the RR.
Michelin CrossClimate SUV come in 275/45/20 but unsure if they would make a good choice given the non OEM tyre size?
Current tyres are 255/55/20
Post #570578 21st Oct 2020 9:41pm
They would be shorter than standard by 1" diameter, so the car would sit 1/2" lower.
275 width is fine - that's the width of the 21 & 22 OEM tyres.
20 wheels are fine
A 45 aspect ratio is too low though
275/50/20 is what you'd want
Just use one of the online calculators - https://tiresize.com/comparison/
Post #570606 22nd Oct 2020 7:41am
FFRR64Royal
Thanks for the tips Alistair Thumbs Up
Post #570688 22nd Oct 2020 8:18pm
FFRR64Royal
Alistair, could I utilise your knowledge once again with a secondary question?
Do you believe the following tyre size would work and importantly fit my 20” alloys?
275/55/20 Cooper AT3 4S
My alloys are these:
I think the offset (if this is the correct term) is 0.5J x 20
Post #571884 4th Nov 2020 8:36pm
Sorry - no idea.
They would be a little taller than stock - probably OK but I can't guarantee that they won't rub somewhere
They would be only very marginally taller (and narrower) than the 285 50 20's that both EM & Vogue fitted - https://www.fullfatrr.com/forum/topic20116-60.html
Post #571899 5th Nov 2020 8:25am
FFRR64Royal
Thanks for the reply and the link Alistair, the link has provided so much great info Thumbs Up
Post #571921 5th Nov 2020 4:27pm
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
Your 20" rims in the picture are marked 8.5J X 20 ...et47. which means that the rim width is 8.5 inches (8.5J) and the offset in mm is 47.
I think a 275 tyre will be too wide for an 8.5 rim. On the L320 Sport 20 inch wheels Land Rover OE fit is 275 tyres on 9.5 inch rims (9.5J) and on the newer Sport L494 the OE 20 inch wheels similar to yours are 8.5J and have a narrower 255 width tyre as standard.
Hope that makes sense!
Post #571924 5th Nov 2020 5:43pm
FFRR64Royal
Seatown.....your description makes perfect sense, and now I can actually see the numbers and make sense of them.
Cooper have the AT3 4S in 265/50/20....would this make a good option?
Post #571925 5th Nov 2020 6:00pm
There is a tolerance in the wheel width - it somewhat depends how straight you want the sidewall - there are benefits to a slightly narrower wheel in terms of protection.
It's not just tyre width & rim width - the height of the sidewall is also a factor in what will fit.
Oponeo (amongst others) have a guide - but seems that 275 45 20 would work on an 8.5 rim with 9.0 being optimum.
https://www.oponeo.co.uk/tools/fit-the-rim-to-the-tyre/275-45-r20
Post #571931 5th Nov 2020 7:18pm
FFRR64Royal
Thanks for the info Alistair and for the link:
265/50/20 work with the 8.5 rim Thumbs Up
Post #571939 5th Nov 2020 9:17pm
Vogue
Yes they will fit fine - I have a set of 285/50/20 on the same wheels - so your size will be fine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #572003 6th Nov 2020 7:11pm
Vogue
275/45/20 are too small for an L405, they are fine for an L322 though. Personally I would (and have) go for 285/50/20, I am also sure Emperor Mong on here used to have a set of 285/50/20 Cooper LTZ’s on a FFRR - a search should find it
Here page 5:
https://www.fullfatrr.com/forum/topic20116...p;start=60 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #572042 7th Nov 2020 9:37am
