Home > Maintenance & Mods (L322) > Repairing dent on corner of rear upper quarter panel |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 |
Sorry, I forgot to attach a photo of the dent in question.
2nd Nov 2020 3:16am |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
Ouch,
2nd Nov 2020 10:39am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
It appears that the paint hasn't cracked, therefore I would search locally for a paint-less dent removal technician. They will advise if they can do it, or it needs a body shop repair.
2nd Nov 2020 12:29pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
that area is very strong point even if you get most of the dent out with a puller it will need prep work and spraying i would
2nd Nov 2020 12:32pm |
Thanks for the feedback, everyone!
2nd Nov 2020 2:23pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
The usual way to remove dents which can't be accessed from the rear is to glue tabs to the dent area using a glue gun and then pull the dent out gradually. If successful you obviously simply heat the glue again to remove it. If you do decide to have a go you will need to get the surface of the dent chemically clean. I think you might find some videos on YouTube showing the technique. |
2nd Nov 2020 2:29pm |
Thanks for all the comments and recommendations again, everyone.
2nd Nov 2020 3:48pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
I have seen this on Insta, no idea if it works, your dent maybe a bit tough, but gotta be worth a go?
2nd Nov 2020 3:59pm |
^ LOL!
2nd Nov 2020 4:46pm |
