![]() | Home > Maintenance & Mods (L322) > Hunter 4 wheel tracking |
| Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201
I had this experience too I don’t understand either way they charge per turn ??? |
| jim4244 Member Since: 31 May 2012 Location: UK Posts: 855
It makes no sense does it Ian?
| 400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65
Modern vehicles are adjustable in many ways. The standard adjustment we all think about is the steering track rod ends, but there are also adjustments that can be done for castor, camber, rear toe in/out etc etc (depending on the vehicles). Its inevitable that most of the adjusters will be seized and will require work to free them off too.
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
I never thought I would ever recommend Kwikfit but I can’t fault them for tracking.
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1531
Wow that's impressive. thanks for sharing.
| Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322
Tracking is as good as the operator. If Kwik Fit has a good chap or chapette then why not.
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
As an example of why trained operators are absolutely essential :
| Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 97
I originally used the specialists at Chesham for my Lexus Sport Cross due to the recognized, less than optimal, factory settings.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
The true test is see if they lock it into Tight Tolerance Mode and ask for a fairly full tank. That’s what the workshop manual says if I remember correctly... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Tracking setup is adjusting the toe angles
Our local main agent charges £235 for a hunter setup on a 405 sir... |
| All times are GMT |
